1 - 9 of 9 Posts
Hey guys, can you see oil leak around 2 front bolts in valve cover ? Same on each bank, oil doesnt appear to be over anything around, just tiny puddle around the bolt head recess. Should i remove valve covers and re-gasket? cheers
I had valve cover gaskets replaced under OE warranty...and they reused the bolt grommets....a no-no...and they leaked and led to exactly what you pictured.
Were yours ever done??
vantaam, ard, E55AMG2, and chowdah
hey thanks guys, looks like item 13 on realoem.com under "cyl head cover", should i leave this till i do spark plugs? only had car 6 wks so not sure whats been done-service records only show basic stuff done.
thanks again for replies.
There are two sizes of washers, i bought numbers 13+14. No need to do them all at once,just change them when they weep oil.
yep, mine was doing the same thing when i got it. no leaks anywhere else just around the front 3 bolts. replaced the rubbers on each side and no more leak. remove one bolt, replace the seal, then reinstall and do the next one. i wouldn't remove all three at once. as said the seals are tough to get over the bolt without tearing so use care. what i did was pop each one in the microwave for a few seconds to warm them up and make them more pliable. just maybe 5sec or so, dont overcook! lol :)
1 - 9 of 9 Posts
