1 - 10 of 10 Posts
Has anyone cut open an Eisenmann full race rear muffler ?
I'm curious as to what the design in inside the muffler
I remember seeing pics of this. It might have been on the e39 page. It was not impressive!
I'm thinking it's 2 perforated straight through tubes with glass packing , can anyone confirm ?
The inner pipes insude the muffler are 50mm diameter
A nice design compromised by noise emission laws , a well made muffler
We will build something similar but with those inner tubes a larger diameter
Not necessarily seeing where the restriction is--the bigger tip opening not lining up with the piping wouldn't matter, and it sort of looks like a straight-through resonator, which is optimal for power. Optimal diameter depends on what the diameter of the B pipe is. If the Eisenmann matches the B-piping diameter then there isn't much point making it bigger.
The pipe sizes are
Inlet 2.5"
Internal 2"
Outlet 3" at the front of the exhaust tip
Sounds like a restriction to me but done I guess to keep noise levels within sort of legal levels.
Hmm that's strange they wouldn't simply make the internal the same, don't think there'd be any scavenging effect way back there.
The Eisenmann race internal pipe in the muffler matches the diameter of a standard M5 exhaust system, for a standard M5 system it could be considered to be non restrictive.
For us the Eisenmann race muffler is a problem / restriction as we are experimenting with a 4 inch internal diameter system
So far we've got some good results , an increase in power and torque across almost the entire rpm range.
We've just modified the exhaust again last night , changed the shape of the centre expansion chamber to reduce drumming and it's made the whole system much quieter.
You can have a normal conversation in the car at idle without drumming or booming , it's somewhere between a stock system and a sport system at idle and low rpm now, at high rpm it's loud
Boot seal air gaps
Something to check if you're getting any booming or drumming with any exhaust system is to make sure that the boot lid seal has no air gaps, it's common to see a 1 or 2cm gap near the boot lock and that will create a lot of noise in the interior as the boot acts like a big sub woofer
1 - 10 of 10 Posts
