If a picture is worth a thousand words this one would be measured with a £ sign in front of it and then multiplied by the german manufacturing factor. Has anyone put a chevy in the M5?!
The fault was the head gasket seal failed. The remaining burn-through erosion occurred over time. You will also notice thatIm no engineer, i have no idea how or why this has happened. The pic shows an interesting pattern to the hole,
you can also see where it looks to be starting across on the other side of the cylinder. I thought id share for those with morbid curiosity.
