1 - 11 of 11 Posts
considering the H&R springs. how do they impact the ride?
I have my m6 with h&r springs and I'm not going to lie to you, ride is not as smooth as it was, you can really notice the difference. On the other hand, handling is much better. I think the same goes to m5s.
I am thinking about picking up some H&R springs. I would like to hear some more imput from others on the board on comfort and performance.
How fat is your ARSE ????
You gots any pot holes????
Does the shelia have any exxcess baggage on her ???
It is sort of a give and take deal. You give some to get some. You have to give up some of that comfort in order to gain some of that handling and lowering look that you want.
Sometimes upgrading the shocks, so that they work with the springs more efficiently can help as well.
-Don
I've had the H&R's for over 50,000 miles, and the best way to describe the ride is that you go up 1/2 setting on your EDC control. 'Comfort' is now halfway between stock 'Comfort' and 'Normal', etc.
I've also heard that the ride with these springs is MUCH stiffer on the M6. Certainly because the M6 is lighter, and possibly uses stiffer shocks.
I would rate the H&R springs+spacers as one of the best mods I've done. If I could only keep one of the mods I've made, that would probably be it.
I agree with Keang24, I installed the HR Springs and 20's the same day and noticed the ride difference. Much firmer. I swapped back to my OEM 19's for a bit and think it is just perfect.
1 - 11 of 11 Posts
