1 - 12 of 12 Posts
Banned
The mass M5 owner opts for the SuperSprint X-pipe but has anyone tried a H-Pipe on their exhaust system?
"An H pipe gets its name because there is a piece of pipe that connects each side of the pipe that connects to the header collectors (hence the name H pipe). This pipe is supposed to help equalize the pressure and thereby create a better scavenging effect. An X pipe however, has each side of the pipe meet in an X type junction. Again the idea is to equalize pressure and create better scavenging. As a general rule, H pipes allow for more low-end torque and slightly less Horse Power than X pipes do. Also, the sound note is quite different. The X pipe has a raspy sound while the H pipe is more “muscle car” sounding. As mentioned, the mid-pipe choice seems to be a personal sound preference and most people who use chambered mufflers opt for the H pipe, while the straight through users tend to choose the X pipe. Typically, the X pipe/straight through muffler combination yields higher HP and lower torque than the H pipe/chambered muffler design. "
I have always heard that the x-pipe is merely an evolution from the h-pipe. It, in theory, accomplishes the exact same thing, but the x-pipe just does it that much more efficiently. I actually read that on this messageboard many years ago. I would run a search about the topic.
'Rocket
it makes sense that the xpipe works better as there is a more direct convergence of the pipes versus the hpipe
the E46 m3 has an hpipe in the stock piping..and let me tell you, it does jack for sound.
Definitely have to agree with that one... hiha
The stock M5 exhaust utilizes an H-pipe design as well. located between the cats and the resonators. I would think that flow would be better thru an x-pipe design but it makes one think about back pressure and whether an h-pipe is designed to provide that balance of back pressure/free flowing air? I do believe the xpipe improves sound quality tho.
al
Banned
From all the M5 exhaust sound samples available I have to agree that the X-pipe adds a "raspy" sound to the exhaust........I can only speak from a previous H-pipe setup on a 302 5.0L engine and it does sound deeper and "mean" ........we'll see how it sounds on the M5....
2000 BMW M5 Avus Blue/Blk. K&N, Royal Purple Racing 51, RP Synchromax, RP Gear-MAX, Redesigned SPEC Billet Stg1 Racing Clutch kit, Lightened Dual Mass flywheel, Rogue Tranny mounts, S03's, ATE Super Blue, Redline WaterWetter, Blinder M20, BEL RX65, 6% SolarGard Titanium, XM, 12inch Rockford Fosgate Sub, PIAA fogs, Invinca-Shield.com
1991 PORSCHE 911 TURBO Blk/Blk. RUF MODIFIED 375RWHP+ 75HP NOS. 200+MPH Street/Race car. K&N, Garettson Intercooler, KKK K29 Turbo, HKS AIC with 7th injector, Full RUF racing coilover suspension, RUF sway bars, SC CAM, DIFF upgrade, B&B headers and muffler, GT2 Adjustable Wing, 3.3L upgraded to 3.5L, Roll Cage, Alpine V12 upgraded sound system, Royal Purple Racing 51 oil, Boost and air/fuel gauges, Big Red Break upgrade, Crossed drilled rotors, Tiresmart, fire extinguisher, 5 point racing harness, Stage 2 HID, no CAT, 18inch RUF Polished Rims, S03's. Obtained fastest lap times in the 90's driven by Al Unser Jr....
1988 VW Jetta Rare "Slalom" Edition wht/gray. K&N, NEUSPEED suspension, MOMO steering/shifter, Euro GTI headlights and bumpers.
2004 VOLVO XC90 AWD 2.5 TURBO wht/blk. K&N
<!-- / sig -->
Banned
Discussion Starter · #7 ·
Banned
Discussion Starter · #10 ·
bmwusa said:
It shouldnt take too long for you to get this all fabbed up, I am looking forward to hearing your setup, Im sure you will, but try and document "photos " of each step if the shop doesnt mind, Im interested in how all this works out, Josh
The DYNOMAX SUPERTURBOS(17784) 2.5" have been ordered......pictures and sound to follow.....
Super Moderator
turbo's and an H pipe, really curious to hear how it sounds, probably great. (i used those mufflers on my 67 gto when i was in highschool!)
Keep us posted.
Mike
1 - 12 of 12 Posts
