1 - 3 of 3 Posts
I have tried with no luck to find the standard M5 Geometry settings and what other people are running. My car is booked in for a full gemoetry set up next Friday at Power Engineering. BMW took my car and after 5 hours said they couldn't do anything because it wasn't standard.........
They already knew this GGrrrrrr.......grrrrrrr
Guidance on Caster, camber, toe F&R would be appreciated and what is and isn't adjustable
Tks
Here are the specified ranges for E39 M5 based on 18" wheels:
LEFT FRONT AND RIGHT FRONT:
Camber -1.00 to 0.00 degrees
Caster 5.95 to 6.95 degrees
Toe 0"0' to 0"10'
Turning angle diff. -2"13' to -1"13'
FRONT:
Cross Camber -0.50 to 0.50 degrees
Cross Caster -0.50 to 0.50 degrees
Total Toe 0"00' to 0"20'
LEFT REAR AND RIGHT REAR:
Camber -2.08 to -1.58 degrees
Toe 0"00' to 0"10'
REAR
Thrust Angle -0"12 to 0"12'
Adrian - you may want to give Biltons of Perivale a call with any specific questions. They are very good for tyre fitting, laser alignment etc. and do lots of work for HROwen sports cars (Lambo dealer). Talk to Slim on (020) 8566 9766.
Hope this helps :byebye:
1 - 3 of 3 Posts
