81 - 100 of 132 Posts
Welcome to the Board.
Fuse 57 is in the trunk. See the picture in the first post.
Most people can tell they need a new FSU if the air conditioning fan acts strangely.
When I enter the car I can heard strange noise behind the radio.
It look like old cassette tape. I was thinking that my old radio is doing this but after replaced it is the same noise so I think maybe this is FSU.
My air condition works fine but for the heating on the outside temp +10 I need about 15min to start heating?
Add me to this list unfortunately. I'm thinking about pulling fuse 57 in the trunk to see if that helps. However, I have the OEM bluetooth setup instead of the phone. Will pulling this fuse kill the bluetooth setup?
I would think it was the FSU, but I just replaced that last year and the AC works great!
Yep I pulled fuse 57 and my Bluetooth stopped working so that won't work for me. Bummer.
Just came across this very helpful post, because, suprise suprise, my car won't start. Its a 2001 facelift with Large Satnav screen, but no telephone. I changed the FSU about 6 weeks ago.
It was parked in Heathrow for two weeks (12th Feb - 1st March) and it was very cold here in the UK at the time. It started fine (albeit cranked over once more than it usually does) and I drove it 45min home.
Then I drove it for a short 10/15min (3mile) journey over to my girlfriends this morning and then moved it again 50meters 10 minutes later.
When I came to start it up again 20min later I accidently locked the car as I cranked it and let go of the key as the engine started to turn (so aborted the start-up).
Then it wouldn't start and the dash was completely dead. I fiddled around with holding down the key buttons and then the dash lit up when I put the key in. Tried to use my girlfriend's battery jumper that she has for her '92 mini, but I think that thing would hardly charge my laptop..!
Bought some jump leads and used my mate's van to jump it and all I got was clicking from the starter motor but the pinon wouldn't engage. He had to shoot, so I couldn't have him idle the car next to mine for 20min to let it charge.
So, I've called out the RAC (as all my tools are at home and you might as well call them if you've paid up) and they are going to come start me.
What could it be? Knackered battery? The car ALWAYS starts in, even below zero (<32F) and I've never had a problem before. Could the 2-weeks parked up at the airport in the cold been the culprit? If so, would the 45min journey home not have been good enough?
These are my thoughts, will put my tail between my legs and see what the RAC man says.
All the more annoying since I've just spent two weeks working in Finland, having to jump start development cars in -29 cold boxes to drive round a snowy track (they always turned over for 20s before firing).
Cheers,
Phil
Verdict -
RAC man came out, very helpful and knowledgable about BMW's of this era.
The battery had a faulty cell - even with the battery d/c from the car, the test equipment he was using still showed a large current draw. Then he put a slightly smaller RAC battery on the car (which he was offering to sell me). It had the same Cranking Amps (920) but smaller. He said it was a 091 battery, the same that our Halfords would stock. When he put that on the car, and let it stabalise, you could see that there was no current draw on it - therefore not the car, but my battery.
£123 and 1hr later, I had purchased the correct Bosch S5015 battery from Wembley Euro car parts and have had no problems since.
One thing to note, after putting the new battery on I got a MIL light within 10min of driving - P0345 - Camshaft Position Sensor A - Bank 2 circuit malfunction. Took a log of the circumstances under which it occured (30.2% calculated load & 21km/h), cleared it, and took it for a short drive to recreate the fault and it didn't re-occur. Will search the forums for some more information...
Also - something interesting I learned from the RAC man (that I hadn't heard before)... After the first time we started the car, the battery voltage (on my old battery) dropped from 12V to 7V and then it cut out. So he said, to drive to the parts shop, connect your battery booster (which from above, was for a 1992 mini, so hardly even lit the dash up) and they will regulate each other which should stop the faulty cell from cutting the car out. Makes sense and got me there OK, but make sure you dock the battery booster carefully in the boot well so that the croc clips don't come off the terminals!
Cheers,
Phil
Reactions: ger
don't do what I did either...
chase all manner of possible faults when it was the oldest one in the book.
poor cold starting, flat battery symptoms even when left on a tender.
car would start fine when warm and instant jump start from the engine bay posts.
new battery, FSU, ignition switch but just a dodgy negative cable earth...!
tried one jumper cable from the -ve terminal to timmays tips and presto, easy start.
even though I'd tightened and removed the cable several times I attacked it with sanding, scraping and some WD-40 and presto, problem solved!
ha!
spoke too soon, should have known auto-electrical witchcraft gremlins are not so easily solved...
starts every time, multiple times when jumped from the engine bay posts.
fails to start at all when cold or after multiple starts.
tried another -ve earth cable and earthing to another part of the body, no use.
looks like some serious current drain when cold, car always on a bettery tender, maybe troubles via the positive side now?
anyone else have some ideas?
Well my car is having problems and has been for quite a while an auto electrician cant find it as it seems to be an intermittent problem was not at work last week so left car on battery conditioner though all was fine but battery flat when I went to start it yesterday!!
So jumped started the car all fine ran her for a few hours put her back on the trickle charger showed charging and the voltage on the battery as just on 12v
Went out into the garage later in the afternoon thought I would check and see what the voltage was and it was now showing 9v With the Trickle charger running
Last night car was flat even with the trickle charger working and connected
So turned it all off and went to bed
This morning battery flat no surprise there
boosted the battery started car all find at 10:50 this morning GMT
let her run until 1150 put it on the trickle charger this showed the green light dull light at 12v
Now I will check her every hour just to see what the voltage drop is over the day and how long it is taking to kill the battery
I replaced the Battery with the correct Bosch item 2 years ago I see that people are saying it is the FSU or BM 54 no idea about any of these will read up on them shortly also I have pulled the fuse for the OEM Phone as the flashing light on the dash did my head in so dont think it is the phone. I also know that the car intermittently dies when I park at the station leaving it at 07:00 hours and returning at about 1600 hours now this is driving me totally nuts.
So currently car has just on 12v at 1140 GMT will post again shortly with voltage level update
find a good auto-electrician, you've got a massive leak on either +ve or -ve side,
finally got mine fixed, it was the old satellite tracker alarm draining current from the ignition side of things.
FSU easy to replace BTW.
An excellent thread this. Alternator is working fine. I've just tested the drain on my battery with the car in sleep mode. It's between 0.001 & 0.002 Amps which is acceptable I think. The only thing I've not tried is extending the multimeter outside the car and activating the alarm to see if that makes a difference. If that doesn't reveal anything untoward it would it would suggest the battery is goosed. Thanks for a very useful topic.
Yes, sounds like the battery, especially if it has a few years on it. You can buy a fairly cheap battery load tester, about CAN$80 over here. Mine has been used many times over the years and has saved a lot of time.
i still have battery drain on my 2001,i have got bored with not knowing if it would start.
so put it away in storage since march..just got it out and parked it up as the storage setups moving.
i have stopped worrying what is causing it ,just disconnected the battery and gave up with it.
Dan
I have a real quick question and I thought this might be the right thread to ask this question... Im conditioning my battery and keeping it slowly charged while its in the garage for the winter. My question is...
"can I have the battery slowly safely charging like this? or should I just unplug the battery and keep it slowly charged with battery itself?"
Also, with the hot and the ground the way they are in our cars will this work alright? Or should I find a better ground area?
Sorry for asking this in here. I couldnt find a Conditioning Battery Thread.
Thanks. Been having drained battery issues last 2 weeks. Went to get a new battery yesterday and was informed by the tech that after testing the battery might not be the issue, and to take it into the dealer for a full electrical inspection. I took a look at the nav system in the back and could see the power light on and hear the cd spinning. I will remove the fuse and hope that solves my problem. I use my phone for navigation so no need of the onboard nav. Thanks for the great write-up.
after dealing with battery drain issues for a while, i followed these steps and determined that the radio/nav unit was the cause of the drain. So i removed the fuses (in the trunk) that control that. so that fixed my battery drain problems, but now i can't use my radio/nav. what is the solution to fixing such a thing? does it require replacement of the radio/nav unit, or is there a less expensive fix?
BIG thanks to the OP for laying out this process so that even someone like me could follow and execute!!
Thanks in advance for any suggestions
