1 - 3 of 3 Posts
German board members, when you take the M5 to Dekra (or similair establishments) for compulsory road safety checkup they run a vibration test of the shock absorbers (stossdämpfern). They usually print the test results. On my car when it had around 60000 kms it was about 80-86% shock absorber damping on all wheels.
As a comparison, would you like to post your mileage and damper test results here, please?
David
This gets at a topic I've often wondered about: how can one determine, quantitatively, when shocks/struts are worn out or getting worn... sure, bounce on the fender, look for oil, but when does a shock start to loose it's damping ability as compared to new?
On the above test, is it 80-86% of new...or is it 80-86% of the government set value for all schocks?
A
I haven´t got a clue really, but would guess the figure means 86% harmonic damping per cycle of suspension "bounce".
The apparatus they use is a vibrating plate that shakes the wheel vertically, and then stops shaking.
David
1 - 3 of 3 Posts
