1 - 6 of 6 Posts
I keep on hearing that the RS6 will have lke 550 hp and the V-10 will come straight out of the Murcielago!
If that is true - it should be able to even beat the M5! (Please also reply to my other thread on "How Is It Possible?" - where I deal with kind of the same issue! :M5rev:
V10 Audi RS6
Audi has made little effort to hide its upcoming BMW M5 fighter, the RS6. We caught it testing at the Nürbur-gring, which means Audi will likely pull the wraps off soon. Right now we know the RS6 will sport similar RS styling cues as seen on the RS4. Like the M5, the RS6 uses a V10 engine displacing about 5.5 liters and producing 550 horsepower.
The tamer S6 will also receive a V10, around 5.2 liters and 440 horsepower. We expect Audi to offer both six-speed automatic and seven-speed direct-shift gearboxes.
no, it WILL NOT beat the m5 because...
1st: the rs6 will have 4wd, which means at least 150lbs more weight and 5% power loss
2nd: the m5 has more than 500hp, most cars were tested around 530hp
3rd: the engine of the rs6 is mounted in front of the front axle while the m5's engine is above the front axle. because of this and the 4wd the weight distribution of the rs6 will not be close to 50/50
1 - 6 of 6 Posts
