61 - 73 of 73 Posts
Discussion Starter #62
Any further updates about release dates?
Hello!
I posted this to M3Forum yesterday as an update:
Sorry for the lack of updates -- life has been super busy lately! In terms of the BlueBus, I am currently working on getting a prototype laid out for the newest revision which adds the following features:
1. Full emulation of the factory TCU from a hardware standpoint
2. A standard 3.5mm audio jack to use with a standard microphone (such as the GROM's).
3. Built-in circuitry to power the OE mic, to do away with the requirement for the "Microphone Adapter".
I expect to have this done by next week.
I'm also working to source Clear Voice Capture licenses for the BC127 Bluetooth module, which is proving harder than I anticipated. My options are an 8 week lead time to have Sierra Wireless build the modules with the license built in, or wading through the murky waters to get the license directly from Qualcomm, which is what I'm currently working on.
Additionally, I'm packing up to move the family from Las Vegas, NV to Southern Ohio in a couple weeks, so that has thrown a wrench in my time-frames. I'm hoping to be ready to take money mid-June and then send the boards off for manufacture. If I don't have to wait for Sierra Wireless to build the modules, then it should be a three week turn around, otherwise I will have to incentivize prospective users to let me old onto their money for 11 weeks or so, then take the money I make there to have more units made.
The 8 week lead time also poses a problem in that I need to pre-pay for the modules, which will be around $7,000 worth.
I'll send an email out to all prospective customers once I have a solid plan for manufacture, which should be in the next couple of weeks.
Thanks!
-Ted
Subscribed and pre-ordered. I'm not a tech guy but it sounds like this is set up for easy install, and will eliminate substantially the only "sigh" from my occasional M5 drive. If only I could get the same functionality for my Audi R8...
Discussion Starter #66
Thanks! The Install should be pretty simple. If you're wanting to add the TCU functionality (hands-free calls regardless of Radio mode), then you'll need to fiddle with a "pick" and some wires to get them de-pinned and moved over to the connector I'll provide. It shouldn't be too hard at all.
Sadly for you, I'm not at all into Audi's :devil
Discussion Starter #69
Thanks for your efforts on this! Preordered.
same same
Thanks guys!
Small update for all: My family and I just moved across the country and we're still waiting on our belongings. I'm still working on the new board revision, but I probably won't have that done until the end of next week, since I don't have a spot to work on it for now.
Thanks guys!
Subscribed and pre-ordered!
Will this still work if my navigation screen isn’t working?
I have that issue where my navigation is corrupted so the screen stays blank, because the battery died, but I can still control the radio by blindly scrolling through channels.
All I need is to stream Spotify through my phone which I can control through my phone. Hopefully it works, thanks for all your effort.
Discussion Starter #72
Thanks!
Sorry for the late reply! Yes it would work, but it'd be really hard to use it without the MKIV in working order as you will not be able to enable pairing.
I can make it work for you by allowing you to initiate pairing via the command line interface, but that would be a PITA for you.
However, wouldn't a GROM BT3 make more sense for you? The big value add for my unit is the OE integration which you will not be able to take advantage of :(
Thanks!
I decided to just purchase an MK4 Unit from eBay since my MK3 is broken. So I will go ahead and buy your solution, as I am trying to keep the OEM look. Looks like it is close to release, looking forward to it.
61 - 73 of 73 Posts
About this Discussion
25 Participants
DonutRanger
BMW M5 Forum and M6 Forums
Full Forum Listing
