1 - 20 of 34 Posts
Administrator
Full set of official BMW M6 pictures & press release
m6board.com Interview with BMW M Manager Ulrich Bruhnke
High res pics in the bottom of this press release
Links to the official Press Releases:
BMW M6 Press Release no 1: World Debut of the new BMW M6 (short version)
Press Release no 2: The new V10 Power Unit in the BMW M6: A Masterpiece in Engine...
Press Release no 3: The Seven-Speed SMG Gearbox
BMW M6 Press Release no 4: The Chassis and Suspension of the BMW M6:Agile, Fast, Safe
BMW M6 Press Release no 5: Body, Design, Equipment: Light and Safe, Sporting and...
Short summary:
The rebirth of an icon
The announcement of a new M car remains a rare and exciting occasion, and the launch of the new M6 in 2005 will reveal a potent new combination of BMW engineering and M power.
Hot on the heels of the new M5, and taking lightweight design solutions from the M3 CSL, the new M6 combines supercar presence with Grand Touring potential. Joining an exclusive club, the fourth new M car of the decade sets a new performance benchmark for a production car. The beauty of the M6 is also its ability to comfortably crush kilometres on a cross-country cruise.
The BMW M6 is the new standard-bearer for BMW’s M car range, as well as the return of a much loved and highly regarded BMW badge. The latest M car features:
* 5.0-litre V10 engine producing 507bhp
* Seven-speed SMG (personally programmable)
* Lightweight body panels including carbon fibre roof
* 0 – 62mph in 4.6 seconds / 62 – 0 in 36 metres
* 155mph limited top speed
* MDrive Manager control settings
Like its predecessor - the legendary 1985 M635CSi – the new M6 resets the sports GT benchmark, with supercar performance, dispatching the zero to 62mph sprint in 4.6 seconds and achieving a limited top speed of 155mph. If derestricted, the M6 would be capable of a 200mph+ top speed. During tests at the famous Nürburgring Nordschleife circuit, the new M6 regularly clocked
eight minutes lap times. These rarefied performance statistics are, however, backed up by ‘real world’ economy and efficiency - the new M6 delivers a combined EU fuel consumption of 19.0mpg and a CO2 rating of 357g/km.
Powered by the same 4,999cc engine that set new standards in the M5, the 507bhp power output ensures that the new M6 maintains the M car tradition of breaking the 100bhp per litre benchmark. Peak power is developed at 7,750rpm with the red line set at 8,250rpm. Peak torque of 520Nm is developed at 6,100rpm of which 450Nm is available from just 3,500rpm. The 90-degree V10 aluminium-silicon alloy engine block is extremely light yet robust and is the first V-arrangement engine to use a bedplate construction. The aluminium bedplate with cast-iron inlays ensures the engine’s rigidity throughout the rev range, but the complete unit still weighs just 240kg.
The capable chassis of the new M6 permits lateral acceleration in excess of 1g. To cope with such forces, the V10 engine features a lateral force-controlled oil supply that, from 0.6g of lateral movement, activates one of two electronic oil pumps to draw oil from the cylinder head and delivers it back into the sump to ensure perfect lubrication even in the most extreme situations. It is because of the extreme forces that can be induced by the M6 that the car also makes use of a semi dry sump lubrication system with an oil reservoir on each side of the front subframe.
Masterminding all the M6’s engine electronics is one of the most advanced engine control systems ever developed. The MS S65 control unit coordinates all engine functions using three 32-bit processors that handle more than 200 million operations per second from over 50 incoming signals. Each of the 10 cylinders has its own throttle butterfly, with its position being monitored 200 times per second. Reacting to changes in throttle position, the butterfly can move from closed to fully open in a mere 120 milliseconds (approximately three times faster than the blink of an eye).
Like the M5, the new M6 also uses BMW’s new third-generation seven speed Sequential Manual Gearbox (SMG) with Drivelogic. Drivelogic offers the choice of 11 different change patterns, depending on the speed of change required. Six change patterns are available in the manual mode and five in the ‘automatic’ mode, in which the gearbox will automatically select the most appropriate gear depending on driving conditions.
The new SMG gearbox also offers safety benefits when downshifting on slippery surfaces. If it detects the rear wheels locking up, the clutch opens for a fraction of a second to ensure traction is maintained. Hill Detection is another SMG feature. In automatic mode, the SMG gearbox recognises that the car is travelling on an incline and holds gears uphill to maintain acceleration and selects lower gears when progressing downhill to make the most of the available engine braking.
The suspension of the new M6 is based on the ‘standard’ 645Ci geometry. With the exception of components such as tie bars, wheel mounts and bearings, the double-arm spring strut front axle is made completely of aluminium. The U-shaped front subframe houses the rack and pinion steering assembly, anti-roll bar and track control arms.
The Integral IV rear axle assembly is also made from aluminium to reduce unsprung masses. In addition, the new M6 features BMW’s variable, speed-sensing M Differential Lock. Featured on all current BMW M models, the M Differential Lock builds up locking action whenever one of the rear wheels begins to spin, channelling drive to the wheel with the most grip to improve handling and stability.
Electronic Damper Control is also standard on the M6. Offering the driver three suspension settings – Comfort, Normal and Sport, drivers can select the most appropriate setting for their driving style or road conditions. The new BMW M6 also features a BMW M version of Servotronic steering with two specific settings corresponding to the Electronic Damper Control settings, Sport or Comfort.
BMW’s DSC stability control system has been adapted for the M6. Featuring M Dynamic Mode (first seen on the new M5), drivers can take their cars to the limit of the laws of physics, allowing considerable angles of controllable oversteer when circumstances allow.
The new BMW M6 comes with a Power button (pioneered in the M5) in the centre console. Initially the car pre-selects the P400 setting, delivering 400bhp for town or city driving, for example. Engaging the Power button modifies the response of the throttle and enables the P500 setting to deliver the full 507bhp generated by the V10 engine.
Control of all of these features has been brought together using the M6’s MDrive Manager. MDrive allows the driver to pre-select specific settings for the Power button, SMG gearbox, DSC, EDC and Head-up Display. With one push of the steering wheel-mounted button, the driver selects his or her chosen character. For example, the car can be set up for an exciting 30 mile A-road drive to and from work or, on the other hand, for a city commute. More extreme settings can be pre-programmed for track use.
For a car with such potential, high performance brakes are needed and the new BMW M6 doesn’t disappoint. Using aluminium double piston callipers and cross-drilled disc brakes, the car can stop from 62mph in just 36 metres and from 124mph (200km/h) in only 140 metres – equivalent to 1.3g deceleration.
Specially developed tyres ensure that the prodigious horsepower and braking power are transferred to the road. Measuring 255/40ZR19 on the front and 285/35ZR19 on the rear, the tyres are mounted on lightweight five-spoke 19-inch forged aluminium wheels, each weighing 1.8kg less than a normal cast alloy wheel.
Like other 6 Series models, the new BMW M6 uses a hybrid construction of aluminium, thermoplastics and SMC (Sheet Moulding Compound). This mixture of materials delivers an extremely rigid, yet light, body structure. The front wings are made of thermoplastics, the doors and bonnet of aluminium and the boot lid, SMC. Like the legendary M3 CSL, but unlike the 630i and 645Ci, the new BMW M6 also uses carbon fibre in the construction of the roof panel to reduce the weight yet further – this feature alone saves nearly 5kg and contributes towards the overall weight of just 1710kg.
Visually, the new M6 differentiates itself from the 6 Series by a deeper front valance with air intakes for the engine and brakes, more contoured sills and rear valance that includes a diffuser to increase aerodynamic efficiency. Nestling under the rear valance are BMW M’s telltale four rear exhaust pipes. To complement the changes in body styling, the new M6 is available in four exclusive M colours – Indianapolis Red, Sepang Bronze, Interlagos Blue and Silverstone alongside three other 6 Series colours.
Inside, the new M6 comes with fully adjustable M sports seats that include lumbar support and an adjustable backrest width as standard. They are covered in extended Merino leather, with the owner able to choose between Black, Silverstone or Sepang. As an option, full Merino leather can be specified in Indianapolis Red and Portland Natural Brown alongside the other three colours that includes a leather covered dashboard and Alcantara headlining.
The new BMW M6 also features BMW M’s version of the new Head-up Display system. Unlike the standard Head-up Display available on 5 and 6 Series models that offers navigation instructions and cruise control information, the system on the M6 projects driver-focussed information such as engine speed, gear selected and road speed directly into the driver’s view, obviating the need for the driver to take his or her eyes off the road ahead.
The new M6 will go on sale towards the end of 2005. Dates and prices will be announced in due course.
Sources: BMW AG
Very high-res pics on the following 14 links:
1 2 3 4 5 6 7 8 9 10 11 12 13 14
Additional low-res pictures in this post.
Re: Full set of official BMW M6 pictures & pressrelease
Thanks for the update.
Those rims are hideous! They look almost ricey.
And that interior is pretty ghastly, too, with that dark wood. Really clashes with the soft silver SMG surround.
The rear bumper also looks too busy.
That red wouldn't be my first choice, either.
I think the transformation of the E60 into an M turned out much better.
I like the wheels, kinda Foose looking. No big deal, easily changed.
I like the interior, but agree that SMG plastic cover is horrible. Not only in this car, but also in the E60 M5.
I find the rear very aggressive, and rather clean. The "hidden" taillights are a plus in my book.
Color is definitely a personal choice. For me Black is the color I love BMW in.
My opinion on the "transformation", the E63 M6 makes the E60 M5 look like a soccer mom's car. :2:
I'm not so sure about the new 5 spoke wheels. I think I'll get the 10 spoke M5 wheels. They look great. That's the only thing that bothers me. Otherwise, the car looks stunning. They've kept the 645Ci side gill metal, which means no standard M gills; interesting. Carbon fibre roof is interesting too. I've always guessed the M6 will look better than the M5, and I'm right!
Geneva March 2005 should be the presentation in complete form. :D :D :D
I get that the wheels can be easily changed, but for me, pretty much every single M-Car in history has had gorgeous rims that I wouldn't touch. IMO, this M6 is the first exception. They should've just put the E60 M5 rims on.
The new 5 spoke wheels seem deliberately designed as such with weight savings in mind.
"With their five contoured double-spokes, these wheels not only look delicate, but are 1.8 kilos lighter than conventional cast aluminium wheels".
Nice try, but I'll be using the M5 wheels.
Not bad, not bad at all!
all the best
adam
I like the wheel
The interior is ... ehh ...ok
The exterior from most views is pretty god but that trunk looks like it was just pasted on. Looks so out of place, plain and simple.
I think I would get it in silver and replace the wheels with some deep dish HRE's.
For some reason it just doesn't look sporty enough and it looks too high off the ground. But I think it is going to be an incredible car none the less. I could deal with the cosmetic stuff just give me that awesome V10 and a good M spec Chasis to go with it. The M divison never ceases to amaze me.
:thumbsup:
Thank you Gustav.
I think it looks okay. Not pretty, but not ugly, just okay. I was really hoping ///M would get a nice one out this time but they went with oaky.
Gustav said:
You're welcome guys and welcome as well to m6board.com!
I think it is crappy looking, I expected something really special to replace the iconic 645csi but it is not in the same class. The standard new 6 series at 333bhp is a real let down and it aint even any fun blowing them away at the lights in my E39 M5 anymore.
Boring and lacks excitement and that lustre you would expect.:confused:
WillM5AD
WillM5AD
I think it looks like "crap" as well. Ugh. It's also missing a clutch in the one interior photo. Ugh. I'll be keeping my E39 M5 for a while as well.
WillM5AD
The E63 M6 will be "... blowing away" your E39 M5 at the lights. So please be more considerate of your comments.
6 Series wins Automobile mag's 'All-Star Design'
The All-Star Design award for the 645Ci is the third design award bestowed on BMW by the editors of AUTOMOBILE MAGAZINE. Selecting the new 645Ci the editors noted, "...once you really look at the 6 Series, what you see is a dramatic, functional, and exciting automobile that stands out like a swan in a gaggle of geese... Let the troglodytes complain. Let them worship the past. We don't care about tradition; we love this car."
:biggrin:
1 - 20 of 34 Posts
