I've read a bunch of posts on tank leaks but none seem to match my issue.
I have Peake Codes:
So far I:
Any other suggestions for where to look?
RR connection point:
LR connection point (blue barb):
LR leak:
RL components for reference:
www.bmwpartsdeal.com
I have Peake Codes:
So far I:
- Replaced the filler cap, but still have the same codes
- Tried smoke testing in two locations in both directions after opening connections at oetiker clamps.
- At the end of the smaller filler tube run where it connects to the tank vent, RR wheel well
- At the bottom of the expansion tank where it connects to the tank vent, LR wheel well.
- There were no smoke leaks found in the engine bay, anywhere in the RR wheel well to include the filler neck and gas cap, under the car or at the tank sending unit areas under the rear seat access covers.
- With the smoke tester hooked up at the LR connection mentioned above, in the direction of the expansion tank, I did see smoke come out of the leak diagnosis pump dust filter. No smoke when the smoke tester was plumbed in the tank vent direction at that connection.
- Probably worth noting my fuel supply line popped up/off at the tank about 500 hundred miles and 2 weeks ago, it has not come off since. I hadn't touched it for 4 years and 18k miles before that. Same codes before and after that event.
LR leak:
Expansion Tank / Activated Carbon Container - 2003 BMW M5 Sedan(E39)
BMWPartsDeal.com offers genuine Expansion Tank / Activated Carbon Container for 2003 BMW M5 Sedan(E39) with great price and fast delivery.
