1 - 8 of 8 Posts
Hello guys, just got an issue with the beast, i did hit the research button but didn't realy find an answer.
Went out this morning driving smooth to let her warm up, once fully warm I went on WOT in M mode passed 7000rpm and yellow CEL poped up :-(
Went back home driving cool and pulled codes.
I have the following codes
DME-2788 Fuel Pressure
Setpoint/Actual-Valve Comparison at Maximum Pressure
DME-Fuel Control Adaptation - Factor Maximum Stop.
Fuel pressure measures 4.8 bars
Nominal pressure 6bars
Fuel pump and filter must be oem.
If i change the pump, will the new filter be supplied ?
For me its the pump, I also have so fuel level reading issues so might sort everything out
First off check that both fuel pump fuses are OK. F30 in the glove box and F72 in the boot. Second pump kicks in at high demand. The filter is seperate and does not come with the pump. The filter is in the left side if the fuel tank and the pumps are in the right.
Cleared the faults and went for a drive this afternoon, error didn't come back. I'm thinking of changing the fuel filter as a start point and if it comes back after that i will change the pump,pumps ??
The fuel filter is a good start, if you were going to change the pump then you should change the filter anyway. At 60k miles, mine was full of dirt, so it could well be your issue.
I am going to change the pump at the same time. When you change the filter you have done half the work of getting the pump out.
1 - 8 of 8 Posts
