1 - 20 of 21 Posts
I tried switching the MAFs and I still got the code, they look fairly new (changed by the prior owner) The car had a cyl 7 missfire with a rough idle. I put the new cyl 7 injector in and now its idling smoothly but the entire bank of injectors are not working. I will try switching my ionic sensors as well. The plenum seems to be on correctly (I sprayed carb clearner post install. and no jumpy idle.
This is ionic current line related. Were you having the fault prior to swapping the ionic units between banks?
Hmmmmm.... yea def try swapping iconic modules and see if Code follows.. i had similar issues but mine were MAF sensor bad
What is the best way to check both- (DME and harness)?
When I purchased the car I had a cyl 7 missfire issue. I changed the cyl 7 injector
Now the entire bank is not displaying fuel injector timing.
Car has fuel pressure (104psi)
The Vanos units are new.
The car also has compression within factory ranges
Valve springs are all good on that bank.
Discussion Starter #11
If I take the rail off; put the car on "On Mode" the injectors should spray right.. I guess I will work backwards on Friday..
Discussion Starter #14
That I'm not sure; but I do wonder when the dealership (Prior to me buying the car) - who did try to troubleshoot (swapped the L/H and R/H mis installed the ionic sensors).
Ok thx ill give that a try... but ive also swapped the coils from one side to the other and now the 1-5 still is the same and im gettin a couple other now here and there (7 &9)
Would u Happen to remember exactly which fuse it was and it’s location? Ive removed the covers already
1 - 20 of 21 Posts
