1 - 4 of 4 Posts
Hi, this is first time I write here, although I've been around to get useful infos. My question is, does anyone know whether the fuel that we use can affect the throttle actuator to throw out a fault? I use 95-98 Octane petrol here in New Zealand, but somehow since I changed from Shell to BP, my car began to throw out a fault code relating to the throttle actuator bank 2. The fault resets by itself but it also very depends on the outside temperature. I would like to hear some opinions before I replace the actual throttle actuator. I wondered if it is the actuator itself is at fault, then why is the fault not always there but on/off irregularly. My mechanic told me that it could be either carbon deposit inside the actuator so one of two sensors inside the actuator is throwing out a fault, or a poor plug connection (less possibility). I've replaced the battery to see if it works but no luck with it. Any opinions? Many thanks in advance.
thanks for reply,, do you know anything on our car, can throw out throttle actuator fault other than the actuator itself? anyone fixed the fault by ECU flash?
1 - 4 of 4 Posts
