1 - 3 of 3 Posts
I have a New DINAN Free Flow Exhaust for an E60 BMW ///M5. That is model year 2006 - 2010. One of the mufflers from this set if an ex-demo unit that was used on display at DINAN. The exhaust system is new, never installed - however, it doesn't come in the box.
This is the exhaust with the Silver / Chrome Tips. This is all I have I do not have the Black Tips system. This exhaust is worth 3 Points towards a DINAN Badge.
It will come complete with all the accessories and parts for bolt on installation. Here is some information from DINAN about the system:
Description
The Dinan M5 exhaust system provides maximum flow characteristics for optimum power gains while producing a civilized, yet very sporty exhaust note that is appropriately aggressive at wide open throttle. And there's none of that irritating low rpm ''drone'' that is common with so many aftermarket mufflers. The mufflers are manufactured from 100% 304 stainless steel inside and out for maximum resistance to corrosion and nearly a 30% reduction in weight, eliminating over 20 lbs.
The four 3.5'' diameter polished stainless steel tips not only give the car a more aggressive look but also feature Dinan's new ''Cool Tip'' design that effectively reduces temperatures in order to minimize radiant heat that can effect body work over time, as well as avoid discoloration of the tips themselves. The Cool Tips also avoid the possibliity of a nasty burn while loading items in the trunk. Employing the principle of rarefaction, the design features an inner and outer tip with a vent at the base. When a positive pressure wave travels to the end of an open pipe and is ultimately expelled into the atmosphere, a rarefaction or momentary drop in density of the surrounding air is created behind it. This momentary drop in the density of the air surrounding the pipe's exit creates a vaccuum, pulling the air from the surrounding area to fill the void. The vent at the base of each outer tip then enables air to be drawn in, effectively cooling the tips
Utilizing the factory brackets and hangers, the Dinan exhaust mounts in a factory-like fashion for a perfect fit and clean installation.
ASKING: $2200
1 - 3 of 3 Posts
About this Discussion
2 Participants
AquilaBMW
BMW M5 Forum and M6 Forums
Full Forum Listing
