Time for a new project...
SPECS-
CAR: 2005 Corvette Z51 6-Speed Blk/Grey, Nav.
BLOCK: SDPC
DISPLACEMENT: 402 cid
COMPRESSION RATIO: 9.5:1
HEADS: West Coast Cylinder Heads Stage II
VALVES: Stainless REV 2.02 intake and 1.57
CAMSHAFT: LAPD Custom Grind 230/230 115LSA
ROCKER ARMS: Comp Cams 1.7 ratio
PISTONS: Manley 2618 -14cc Dish
CRANKSHAFT: Callies 4340 Crank
RODS: Scat H-Beams 6.125”
INTAKE MANIFOLD: FAST 90mm Composite
THROTTLE BODY: 90mm LS2
FUEL INJECTORS: 60-LB Mototron Low Impedance
FUEL PUMP: Stock GM, MagnaVolt Fuel pump Booster
FUEL SUPPLEMENT: AlkyControl Progressive kit (dual nozzle)
IGNITION: Stock Coil Packs, MSD 8.5 mm Plug Wires
ENGINE MANAGEMENT: Stock GM PCM, HP Tuners Speed Density tuned by DOUG STALTER @ Los Angeles Performance Division
POWER ADDER: APS Twin Turbo C6 System (modified)
MAXIMUM BOOST: 14.5PSI
INTERCOOLER: Dual APS High-Efficiency Intercoolers
TURBO ACTUATORS: Forge Motorsports Billet
BLOW OFF VALVES: Forge Motorsports Billet
EXHAUST SYSTEM: KOOK 3” Mid-Section, B&B Bullet, Royal Mufflers Custom Fabrication.
TRANSMISSION: Stock T56 Six Speed, Callaway Short Shifter
CLUTCH: GM LS7
DRIVESHAFT: Stock
FRONT SUSPENSION: PFADT Racing Coilovers; Hotchkis Sway Bars
REAR SUSPENSION: PFADT Racing Coilovers; Hotchkis Sway Bars
REAR END: Stock with 3.42 gears
FRONT BRAKES: Wilwood 14” SL6- Piston, PolyMatrix Pads
REAR BRAKES: Wilwood 14” 4-Piston, PolyMatrix Pads
CURRENT MILEAGE: Car- 14,800 miles, Engine- 5,000 miles
EXTERIOR-
Lingenfelter Commemorative Edition C6 Custom Hood
WCC Carbon Fiber Rear Exhaust Panel
Custom Carbon Fiber Brake Light Spoiler
WHEELS: C6 Z06 Aftermarket; 18x8.5 fronts, 19x12 rear Blk Powder Coated “Time Attack Red”
FRONT TIRES: Michelin Pilot Sport 2, 245/40/18
REAR TIRES: Goodyear F1 Supercar EMT, 325/30/19
Custom A-Pillar Carbon Fiber
Blackouts: Emblems, Tail lamps & Side markers
Bi-Turbo Emblems
INTERIOR-
Blitz SBC I-Color Electronic Boost Controller
Autometer Cobalt Gauges: Boost, Fuel Pressure and Wideband
Callaway Short Shifter (OEM knob)
Lingenfelter "LPE LOGO" Floor Mats
Lingenfelter "LPE LOGO" Trunk Mats
UNDERHOOD AMENITIES-
Lingenfelter Fuel Rail Covers (blk. w/red lettering)
Carbon By Design: CF Accesories
Optima Yellow Top
LAPD Clutch Bleeder
West Coast Corvette Blk Aluminum Engine Cap Set
Oops...forgot to mention the license plate is not included in the sale, I'll be needing that for the next project.
Majority of the performance/service work done By Los Angeles Performance Division (LAPD) in Chatsworth, Ca.
Car is garaged and meticously well maintained; no dents, dings or scratches. Proper monthly paint conditioning. The car was featured in Vette Magazine in Feb. 07, a full feature in an upcoming issue.
Over $50K invested in this car! My asking price is $64K....serious buyers only please.
More pictures can be found here -
http://forums.corvetteforum.com/showthread.php?t=1878487
My contact # - 818.429.2526
Thanks for viewing.....Richard.
SPECS-
BLOCK: SDPC
CLUTCH: GM LS7
DRIVESHAFT: Stock
EXTERIOR-
Bi-Turbo Emblems
INTERIOR-
Optima Yellow Top
LAPD Clutch Bleeder
