1 - 17 of 17 Posts
Up for sale is my 2003 M5 that I purchased in March 2017 from Seattle. Since then, I've invested a considerable amount of time and funds into restoring the car. Everything I've done is documented in my thread, but I'll summarize the work here as well. Reason for the sale is to focus more on my house as every old BMW requires constant maintenance and I'm (reluctantly) shifting priorities. It's been the most satisfying car I've ever owned. Currently at 116k miles.
The car was originally ordered to have the following Dinan parts installed at the Florida dealer in 2003:
  • Cold Air Intake
  • Mass Flow Meters
  • Strut Tower Brace
  • Exhaust
  • 3.73 LSD
  • Stage 3 Software Tune
The Dinan exhaust was replaced with the stock version at some point followed by the muffler-delete mod. The car had the Dinan badge on the trunk but since the previous owner drilled it to install the E36 wing, I had to get a clean trunk from a 525i, painted it to match, then installed the proper E39 spoiler.
Here is the Carfax for the car. Unfortunately I don't have any more details or info regarding the accident beyond what's written in the report. The car did not have any structural damage, the title is clean, and the car hasn't exhibited any signs of damage. BMW Seattle performed a PPI when I bought the car and nothing out of the ordinary was observed. Between the Carfax and all my photos/documentation, the entire history of the car is essentially available.
List of Wear & Tear Items
DATESERVICE/PART
3/11/2017Pre-Purchase Inspection
3/11/2017Airbag Replacement (recall)
3/11/2017Accessory Belts (A/C & Water Pump/PS/Alternator)
3/15/2017Door mirror without glass (passenger side)
3/16/2017Liqui-Moly 10W-60 Oil (7 liters)
3/16/2017Oil filter kit
3/16/2017Oil filter wrench (36 mm by Hazet)
3/20/2017Royal Purple Synchromax Manual Transmission Fluid (3 qts)
3/20/2017Royal Purple 75W-150 Gear Oil (2 qts)
3/20/2017Fluid Pumps (qty = 2)
3/20/2017Shifter Rebuild Kit
3/20/2017E60 Shifter
3/20/2017ZHP Shift Knob
3/21/2017Center Dashboard Vent
3/21/2017Door Panel Clips (natural)
3/21/2017Door Panel Clips (yellow)
3/21/2017Spare shifter circlips for shifter rebuild
3/21/2017Spare plastic washers for shifter rebuild
3/27/2017Porterfield R4-S Brake Pads (Front & Rear)
3/28/2017Coolant Temperature Sensor
3/28/2017Coolant Level Sensor
3/28/2017Brake Fluid DOT 4 (2 liters)
3/28/2017Brake Bleeder Bottle Set
3/28/2017Disk Brake Pad Spreader
3/29/2017///M Floor Mats
4/6/2017GPS Antenna Cable
4/10/2017Timing Chain Tensioner
4/10/2017Radiator Fan Clutch
4/10/2017Water Pump Pulley Tool
4/10/2017Fan Blade
4/10/2017Upper Radiator Hose
4/10/2017Lower Radiator Hose
4/10/2017Radiator Drain Plug
4/10/2017Radiator Mount Support - Upper
4/10/2017Radiator Mount Support - Lower
4/10/2017Coolant Expansion Tank
4/10/2017Expansion Tank Cap
4/10/2017Drain Plug Gasket (used for timing chain tensioner)
4/10/2017Speed Nuts
4/10/2017Body Nuts (Pack of 10)
4/10/2017Body Securing Nut
4/10/2017Screw with Washer
4/10/2017Oil Level Sensor O-Ring
4/10/2017Fuel Filter
4/10/2017Gas Cap
4/10/2017///M Valve Stem Cap (set of 4)
4/10/2017Torx Bolt (pack of 10)
4/10/2017Front Brake Cooling Duct - Left
4/10/2017M5 Replacement Emblem
4/10/2017Plastic Cover for Deck Lid (qty: 2)
4/10/2017Plastic Expanding Rivet (qty: 14)
4/10/2017Lower Body Cover - Left
4/10/2017Lower Body Cover - Right
4/10/2017Front Fender Liner - Left
4/10/2017Front Fender Liner - Right
4/10/2017Body Nut (qty: 10)
4/10/2017Flat Washer (qty: 4)
4/10/2017Circlip (qty: 8)
4/10/2017Self Tapping Screws (pack of 10)
4/10/2017Expanding Nut (qty: 6)
4/10/2017LED Trunk Lighting Kit
4/13/2017Front Fender Splash Guards
4/13/2017Lower Radiator Hose (thermostat to radiator)
4/13/2017Fan Shroud Rivets (qty = 4)
4/13/2017Black Lug Bolts (qty = 20)
4/13/2017Trunk Trim Support Bracket
4/19/2017Spark Plugs (NGK 3199 BKR6EQUP)
4/19/2017Spark Plug Boots (qty = 8)
4/19/2017Adhesive Tape for Trunk Lid Spoiler
4/19/2017Oil pump chain tensioner
4/20/2017Hex Head Screws (qty: 12)
4/20/2017Ultimate Valve Cover Gasket Set
4/20/2017Lower Oil Pan
4/20/2017Oil Pan Gasket
4/20/2017Intake Manifold Gasket
4/20/2017Ignition Coils (qty: 8)
4/20/2017Fuel Tank Breather Valve
4/20/2017Fuel Pump Assembly
4/20/2017Front Brake Cooling Duct - Right
4/20/2017M5 Matte Shadowline Trim Kit
4/21/2017Trunk Lid from 525i
5/15/2017Hood and Trunk Emblems/Roundels
5/15/2017New OEM front bumper cover
5/15/2017Painted front bumper cover & trunk lid; polished headlights
5/22/2017Dinan air filters (qty: 2)
5/25/2017Hex Head Screws (qty: 12)
5/25/2017Rivets for Lower Plastic Covers (qty: 12)
5/25/2017Windshield Molding Trim
5/25/2017Wiper Blade Set (Bosch)
5/31/2017Power Steering Line O-ring (qty: 3)
5/31/2017Power Steering Reservoir
5/31/2017Hose Clamps (Spring Type)
6/9/2017Oil Separator - Bank 1
6/9/2017Oil Separator - Bank 2
6/9/2017Gasket - Intake Cover to Oil Separator (qty: 2)
6/9/2017Oil Separator Hose - From Engine Air Intake Collector
6/9/2017Oil Separator Hose - Bottom of Oil Separator
6/9/2017Oil Separator Hose - Top of Oil Separator - Bank 1
6/9/2017Oil Separator Hose - Top of Oil Separator - Bank 2
6/9/2017Adjusting Pulley Assembly - A/C Compressor
6/9/2017Adjusting Pulley Assembly with Two Idler Pulleys - Water Pump/Alternator
6/9/2017Drive Belt Tensioner - A/C Compressor
6/9/2017Drive Belt Tensioner - Water Pump/Alternator
6/9/2017Gasket - Intake to Throttle Bodies - Bank 1
6/9/2017Gasket - Intake to Throttle Bodies - Bank 2
6/9/2017Vacuum Hose 3.5 x 7.5mm
6/9/2017Radiator
6/9/2017Control Arm with Bushing (Traction Strut) - Left
6/9/2017Control Arm with Bushing (Traction Strut) - Right
6/9/2017Control Arm with Bushing (Wishbone) - Left
6/9/2017Control Arm with Bushing (Wishbone) - Right
6/9/2017Guide Link for Wheel Carrier (qty: 2)
6/9/2017Rear Sway Bar End Link (qty: 2)
6/9/2017Flat Washers for Both Belt Tensioners
6/9/2017Check Valve (Under Plenum)
6/9/2017Air Hose Elbow (qty: 2)
6/9/2017Conduit (Under Plenum)
6/9/2017Support (for Vacuum Line Under Plenum)
6/9/2017Vacuum Line
6/24/2017Oil Filter Kit
6/27/2017Vacuum Hose
6/27/2017Rubber Mounting for Power Steering Reservoir (qty: 2)
6/29/2017Hex Bolt for Water Pump Pulley (qty: 4)
6/29/2017Hex Bolt for Power Steering Pump Pulley (qty: 3)
6/29/2017Water Pump Pulley
6/29/2017Power Steering Pump Pulley
7/18/2017Nylock Nuts for Velocity Stacks (2, 10 Packs)
7/18/2017Engine Beauty Cover Gasket (qty: 2)
7/18/2017Power Steering Hose - Return Line
7/18/2017Power Steering Hose - Suction Line
7/18/2017Throttle Position Switch (qty: 2)
7/18/2017Hex Nut with Flange for Rear Toe Link (qty: 4)
7/18/2017Self-Locking Collar Nut for Rear Sway Bar End Links (qty: 2)
7/18/2017Rubber Mounts for Oil Filter Housing (qty: 2)
7/24/2017Scavenger Oil Pump O-Ring (qty: 2)
8/1/2017Oil Pan Gasket
8/1/2017Oil Level Sensor O-Ring
8/13/2017Valve Cover Gaskets - Bank 2
8/13/2017Hose from Idle Control Valve to Lower Plenum
8/13/2017Nylock Nuts for Velocity Stacks (3, 10 Packs)
8/30/2017Driver's Side Mirror
9/4/2017Fuel Pump Relay
9/4/2017Driver's Door Light Assembly
10/9/2017Headlamp Trim Seal (qty: 2)
10/9/2017Headlight Gasket (LH & RH)
11/6/2017Painted Hood
11/6/2017Hood Insulation
11/6/2017E60 Windshield Wiper Nozzles (qty: 2)
11/15/2017Windshield Nozzle Hose
1/20/2018Oil Filter Kit
1/20/2018Front Sway Bar End Links (qty: 2)
2/17/2018Repainted Wheels via Jed Pineda
2/17/2018Remanufactured Power Steering Pump
2/17/2018Power Steering Pump Crush Washer
2/17/2018Oil Level Sensor O-Ring
2/17/2018Oetiker Clamps
2/17/2018///M Wheel Emblem (qty: 4)
3/4/2018Hood Release Lever & 2 Torx Bolts
3/4/2018Firewall Covers (Left & Right)
3/4/2018Cabin Air Filter Ducts (Left & Right)
3/4/2018Cabin Air Filters (Mann)
3/11/2018Rear Door Vapor Barriers (Left & Right)
3/11/2018Door Panel Clips (qty: 20)
7/12/2018Front Upper Control Arm
1/24/2019Michelin P4S Tires (all 4)
2/18/2019M Badge for Wheel
2/18/2019Hella Oil Level Sensor
2/28/2019Air Pump
2/28/2019Rubber Mounts for Air Pump
4/3/2019Hood and Trunk Gas Struts
List of Mods
DATESERVICE/PART
3/21/2017Black License Plate Frame
3/21/2017Black Kidney Grilles
3/28/2017Navigation Upgrade DVD
3/29/2017Trunk Lid Spoiler
3/31/2017Weld new exhaust tips
3/31/20172 License Plate and 2 Fog LED Lights
3/31/2017Interior Ziza LED Kit
4/2/2017M-Stitch Shift and Parking Brake Boot
4/5/2017Tint (20% Color Stable 3M & 70% Crystalline)
4/10/2017M Oil Cap
4/15/2017Rear Finned Diffuser
6/6/2017Dinan CARB Sticker for CAI
9/17/2017Projector39 Hella Style Headlights
10/27/2017Bluetooth Audio and DSP Conversion Kit
12/14/2017Eibach 18mm Rear Sway Bar
12/14/2017BeastPower Rear Sway Bar Brackets
1/20/2018Shorter Valve Stems (qty: 4)
2/10/2018Wheel Center Caps (qty: 4)
3/9/2018Re-wrapped M Technica Steering Wheels
4/13/2018Double Shear Selector Rod (DSSR)
List of Service/Maintenance Items
DATEMILEAGETASK
3/18/2017 106,497Replaced passenger side door mirror
3/19/2017 106,524Oil & filter change
3/24/2017 106,621Differential oil change; transmission fluid change, both pre-cat O2 sensors changed
4/1/2017 106,730R&R all brake pads; brake fluid flush
4/23/2017 107,100Installed E60 short shifter
5/20/2017 107,389Installed new front fender liners, new splash guards, brake ducts, replaced timing chain tensioner
5/26/2017 107,477Replaced Dinan CAI air filters
6/2/2017 107,606Power steering fluid flush; installed new power steering reservoir
6/7/2017 107,755Replaced fuel pump and fuel filter
6/9/2017 107,7834-Wheel Alignment and Passenger Side Tie Rod Install @ West End Alignment
6/16/2017 107,912Drained coolant from the radiator and the block, replaced: radiator, expansion tank & cap, all 3 radiator hoses, coolant temp sensor, both idler pulley assemblies, both belt tensioners, and water pump pulley
6/21/2017 108,012Replaced all 4 control arms in the front suspension
8/12/2017 108,306Replaced bank 2 valve cover gasket and all nuts, gaskets, and bolts
8/12/2017 108,306Replaced lower oil pan and gasket, and oil level sensor gasket
8/12/2017 108,306Replaced oil pump chain tensioner
8/12/2017 108,306Replaced both throttle position sensors
8/12/2017 108,306Changed oil and oil filter
8/12/2017 108,306Replaced all coil packs
8/12/2017 108,306Replaced all spark plug boots
8/12/2017 108,306Replaced all spark plugs
8/12/2017 108,306Replaced throttle body gaskets (both sides)
8/12/2017 108,306Replaced oil filter housing rubber mounts
8/12/2017 108,306Replaced oil pump solenoid valve O-rings on both sides
8/12/2017 108,306Replaced check valve and vacuum lines
8/12/2017 108,306Replaced power steering pump pulley
8/12/2017 108,306Replaced oil separators, gaskets, and associated hoses
8/12/2017 108,306Replaced rubber hoses on lower plenum manifold
8/12/2017 108,306Replaced plenum gasket
8/12/2017 108,306Cleaned throttle bodies
8/19/2017 108,306Replaced bank 1 valve cover gasket and all nuts, gaskets, and bolts
8/19/2017 108,306Replaced fuel tank breather valve
9/3/2017 108,600Replaced driver side door mirror
10/7/2017 109,302Replaced power steering suction hose
10/14/2017 109,393Installed Umnitza Headlights
12/24/2017111,300Installed Eibach sway bar, BeastPower brackets, and new end links
2/23/2018112,115Replaced front sway bar end links, replaced smaller rear control arms, tightened parking brake; work done by Jed Pineda
3/3/2018112,191Replaced power steering pump
3/3/2018112,191Changed oil and oil filter
3/26/2018112,310Replaced rear left & right door vapor barriers
3/31/2018112,370Replaced both firewall covers, both cabin air filter ducts, and air filters
4/3/2018112,385Installed new steering wheel and clutch stop.
4/20/2018112,835Installed UUC Double Shear Selector Rod; Jed's Unicorn Nuggets, and replaced all shifter bushings; replaced exhaust gaskets (qty: 2), re-welded exhaust cracks; installed new shifter rubber boot
5/6/2018112,887Replaced front passenger side window regulator and added O-rings to all door clips
2/16/2019114,774Replaced left lower control arm
2/22/2019114,7794-Wheel Alignment @ West End Alignment
2/22/2019114,779Oil & filter change; replaced oil level sensor & associated nuts
4/23/2019115,000Replaced hood and trunk gas struts
5/26/2019115,100Replaced rubber brake lines inside engine bay; bled brakes; replaced air pump
Needless to say, the car has received some proper TLC. :)
Asking price: $25k
First set of photos:
I don't have any documentation but wanted to add that according to the previous owner, the clutch, water pump, and thermostat were replaced at 80k miles.
is it just the muffler delete and not the resonator? trying to gauge how load it is, outside and in the cabin
The resonator is still installed so there's no drone at all.
If you search this forum, you'll see the muffler delete mod is very popular because it's civilized when driving normally, but loud when you really get on it. Best of both worlds. No one's ever complained that it's too loud inside the cabin.
I have seen thousands of FS ads for e39s and e39 M5s and yours is ....making me drool. Your whole thread of how you bought the car, the road trip and beautiful photography, so perfect. The list of parts and services is absolutely insane! I don't know how you could sell a car you have invested so much time, money, and attention in...but I get it, life priorities. It is as perfect as an e39 M5 could be! I think $25k is a steal for a car with this level of TLC. I wish this was for sale earlier this year! I would have snatched it up before I got my e39. Good luck with this!!
Discussion Starter #11
Appreciate it! It's definitely been fun and a labor of love. At this point I've already taken care of the majority of items that needed attention and feel like I'm letting it go now that it's "ready," but I've also enjoyed it long enough to feel good enough about the ownership experience.
Unsurprisingly, I really enjoy the documenting process and been doing the same with my Cayman.
I'm hoping in the future I can restore either an E24 M6 or 2002. Or a GTV 2000. Or an original Mini.
Car ADD is a real disease. :)
Couldn’t agree more, easy to be enthusiastic about these kinds of cars. I have always wanted the e24! It is The second car I’m after to keep for good. First the e39. And now I’m looking to get a 635csi. Paint or wrap it black and get some white or caramel seats...
Thanks again for sharing!
1 - 17 of 17 Posts
