1 - 1 of 1 Posts
2000 M5 for sale.
$7900 obo
Current pictures are here:
Index of /4sale/2000-m5 (these pictures were taken on 3/28/2014)
I bought it in September 2007 with 75K miles.
The car now has ~165K miles.
Heated seats, sport button, stability and traction control, PSC, suede headliner and rear shelf, navigation, 6 disk CD changer, AC works.
Car used to have a phone system, but I have removed it and installed a storage console in center armrest
Comes with 2 sets of wheels:
1. 4 rear stock rims 18x9.5 - no tires on them
2. Sport Edition 17x8 with Michelin X-Ice 245/45-17
5mm spacers in the front
Fenders have been modified to run 19x10 ET25 with 275/30-19
I also had stock rears in the front with 275/35-18 with no spacers and no rubbing
TC Kline nascar style stud/nut conversion instead of stock wheel bolts
Has all the options according to the dealer spec sheet including fold down rear seat with ski bag and rear PDC.
This car was originally sold in North Carolina and then sold again as a CPO in North Carolina.
I am the third owner. I have all the service records on the car since new. At one point in it's life there were some Dinan intakes installed on it, but I got the car with without them.
Instrument cluster was replaced in 2005, no dead pixels.
Here's the list of repairs and maintenance that I have done on the car since I've owned it.
- Oil and filter changes every 5K miles with BMW/Castrol 10w-60 oil
- Brand new BMW floor mats (October 2007)
- Replaced self dimming rear view mirror with brand new BMW unit (January 2008).
- Brand new rear brake pads - Hawk HPS (August 2009)
- Brand new front brake pads - Hawk HPS (September 2008)
- Installed european front brake cooling ducts (September 2008) and modified front mesh grill to let the air in the ducts.
- Replaced plastic splash shields around front wheels with european units and front under tray. New from BMW (September 2008)
- Rebuilt both Vanos units: all new seals, gaskets, solenoid boards (May 2009)
- Replaced Vanos solenoid seals with upgraded seals from DrVanos (May 2009)
- Replaced all 4 camshaft position sensors and gaskets (May 2009)
- Replaced gas tank vent valve (May 2009)
- Replaced thermostat, coolant (BMW), spark plugs, filters (air, oil, cabin air), valve cover gaskets, valve cover bolt gaskets, intake seals, accessory belt, adjusted the timing (May 2009)
- Replaced rubber grommets that hold oil filter housing and PS reservoir (May 2009)
- Replaced oil filler cap with new BMW unit, had some silly AL piece with ///M emblem on it that was leaking (May 2009)
- Dealer reprogrammed ECU with the latest updates after the installation of new parts (May 2009)
- Brand new battery from Autozone - direct fit. (October 2009)
- Replaced all 3 PS hoses with seals and washers - new from BMW (May 2009)
August 2010
- Replaced all suspension/steering arms, links, ball joints front and rear
- Rear Eibach sway bar
- Ground Control coilovers front/rear
- Koni Yellow shocks SA from GC
- Ground Control front camber plates (stock suspension will be included)
- Replaced rear trailing arms bushings with spherical bearing mounts Index of /2000-M5/rta-monoballs
- Replaced rear subframe bushings
- Replaced diff bushings
- Replaced all 4 wheel bearings
- UUC Fidanza 850csi flywheel
- Spec Stage 3 850 csi clutch kit
- Changed rear main seal
- 850csi clutch slave cylinder
- 545i medium short shifter
- Changed shifter bushings/joints
- Urethane transmission mounts
- Rebuild LSD unit with new clutches, changed setup to 3 clutches instead of 2.
- Changed diff o-rings and seals
- New exhaust supports/hangers/seals
- Royal Purple oil in tranny and diff
- 4 wheel alignment at BMW dealer
- Replaced both MAFs
- Replaced spark plugs
August 2011:
- Replaced drivers door
October 2011:
- Replaced airbag module with new Original BMW part (old one died during door replacement), programmed it to the car
- Replaced front cupholders
- Replaced rear cupholders with storage tray
- Removed phone system and replaced phone tray with storage tray in center console
February 2012:
- JB racing V12 clutch kit (UUC unit has dies prematurely) with stock Sachs 850 CSi clutch balanced by JB Racing
- Master clutch cylinder
- Differential front bushing
- Transmission mounts
February 2014:
- Radiator support
- Hood
- Serpentine belt
- Front tie rods
- Front end alignment
- Hood emblem (original BMW)
There's probably more that I don't remember. I have a stack of records about 1.5 inch think. I have done most of the work myself, have receipts for parts.
2 accidents during my ownership.
1. 2011: F350 drove into driver's door taking off the traffic light
Pics:
Index of /2000-M5/accident-f350
I've replaced the door, there's still a small dent on rocker panel.
I have a door harness, door handle, and window regulator left over, will be included
2. 2013: My wife rear ended Suzuki Vitara taking off the light.
My insurance company totalled it in September 2013 after accident #2.
The only two things that needed replacing were hood and radiator support which I have replaced.
Pictures right after the accident are here:
Index of /2000-M5/accident-2013
Currently it could use new brakes, check engine light is on occasionally, has some vanos codes.
Hood had a dent which I didn't notice until I installed the hood, so I decided to hold off on paint. Maybe a CF hood?
PDC does not work, need new sensor which I have.
Lots more pictures of the car and it's progress/repairs/modifications since I've owned it:
Index of /2000-M5
Please contact me with any questions.
Email, text or call
T: 518-772-7075 -- Alex.
Thank you!
1 - 1 of 1 Posts
