1 - 16 of 16 Posts
I've done some searching and while there are many threads I can't find anything specifically about how to remove the cup holder. Google gave me just enough info to make me think it's not as straight forward as removing the 2 screws that can be seen when opening the cup holder. So.. is there some trick to this? The reason I want to do this is so that I may drill a small hole in the plastic face to the left of the cup holders in order install an AUX input 3.5mm jack.
Thanks!
It's as easy as removing the 2 screws. I removed the POS holders:
And replaced them with this:
I have since spray painted it black to blend better.
I did this when installing my water methanol system to help clean up this area.
Thanks ECB. I read some posts on other boards stating that there was some kind of internal tongue that needed to be depressed with a bent coat hanger, etc etc. Had me a little worried!
There is a tongue. After removing the two screws you have to depress it to slide out the cup holders. I settled for ripping my cup holders out forcefully because after 30 minutes I could not get them out.
I now have the same cover as ECB. They have it in gray like in his picture and in black which I have wrapped up somewhere and haven't checked to see if it matches. Other option is CF wrap.
Discussion Starter · #7 ·
Ok so any tips for getting the thing out without breaking it? I'd like to put it back in afterwards! :)
You can try using a credit card or other similarly sized, firm piece of plastic to release the tounge, but I've found that in a lot of cases once the holder has broken the internal parts go everywhere and the easiest solution involves brute force. In every E39 where I've replaced cupholders the old one tends to come out in 4 - 6 pieces.
Discussion Starter · #9 ·
I see. My cupholders aren't broken.I just need to drill a small hole in the left side of mine to mount a 3.5mm jack.
Discussion Starter · #11 · (Edited)
That is exactly where I'm going to mount it however I have an 03 so I'm building a proper cable to connect behind the monitor. Hopefully my trim piece wont stick out like the one in the photo you pointed to.
I don't think you need anything except a screwdriver to get this thing out. I didn't. Pulled it straight out (easily) after the 2 screws were removed. The center air vent...well now...that's a different story!
I'm trying to diagnose a driver seat heater issue. Spent today removing the seat and removing the leather covering. I should have checked the switch first. Anyone know how to remove the seat heater switch? Currently I am wrestling with the cup holder. I'll use my credit card as suggested.
Thanks. James
I used a credit card it popped right out. As for the center control console, if you reach under with your palm facing up, you can pry it out with your BMW special tool. Just kidding - use your fingers.
Good info, mine's comming out next week. Replacing it with a delete plate as well.
1 - 16 of 16 Posts
