1 - 4 of 4 Posts
02' Carbon Black M5 & 11' Alpine White 335D M Sport
Hey guys, I have to replace the HVAC blower as the bearings are dry and making crickets in my dashboard :Thumbdown:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
http://www.bmwtips.com/tipsntricks/AC/smell.htm<o:p></o:p>
<o:p></o:p>
I looked at the above and it seems for the E39 you have to drill holes into the case, not to fond of drilling into a $500 piece of plastic and risk drilling into the Evaporator :eek:h: so I’m hoping access is easy while I have the blower out anyways..<o:p></o:p>
Discussion Starter · #2 ·
Bump...
Anyone have any info?
Problem is the mold seems to live on the inside part. I tried just blasting several doses down and letting the fan blow it into the rads, no help. Drilled my hole and did it from inside and had a huge improvement. I did not drill the big hole just a little one and used the top and tube off a WD 40 can, put it on the Lysol can. I did it from both sides.
You may do well with calling ServPro to get things taken care of. They can let an ionizer run in the car for a couple hours. Make sure to apply some dressing on door seals and other rubber items in the car after as ionization does promote deterioration of rubber, if I recall correctly. Some may disprove me on this.
1 - 4 of 4 Posts
