1 - 3 of 3 Posts
2007 BMW E60 M5 SMG, 106,000 miles. Full service records under my ownership since 54,000 miles in 2013 to 106,000 miles present. Never track. Title in hand. Car located in New York City. Looking for $28,000.
Exterior: Silverstone II
Wheel: OEM Lolipop Red powder coated (No scratch)
Interior: Silverstone (dyed to black color)
Engine oil: Redline since 75948 mls.
Maintenance / Replacement:
09/10/2013 54400 MLS
REPLACE X1 IGNITION COIL
PART# 12137841556
09/26/2013 54500 MLS
AFE PRO DRY S AIR FILTER INSTALLED
10/04/2013 55000 MLS
FRONT & REAR BRAKE PAD REPLACED
CABIN FILTER (X2) PART# 64319171858
10/19/2013 55250 MLS
WINDSHEILD WASHER PUMP REPLACED
PART# 67127302589
12/27/2013 55500 MLS
POWER STEERING RESERVOIR SEAL REPLACED
03/02/2014 55800 MLS
ALL 4 SOLENOID REPLACED
PART# 11367841072
03/18/2014 60000 MLS
ENGINE OIL AND FILTER CHANGED
BEHR HELLA SERVICE OIL COOLER REPLACED
PART# 17222282499
ANTIFREEZE COOLANT FLUSHED
03/27/2014 60500 MLS
ALL FRONT & REAR SUSPENSION REPLACED
PART# 31352283071 (X2)
PART# 31126774825
PART# 31126774826
PART# 31306781547
PART# 31306781548
PART# 31126768297
PART# 31126768298
PART# 33306772241
PART# 33306772242
PART# 33326779820
04/15/2014 60900 MLS
PIAA 97351 SILENCIO XSILICONE WIPER REPLACED
05/08/2014 61200 MLS
REAR DRIVER SIDE SHOCK (USED‐32K) REPLACED
PART# 33522283990
05/16/2014 61350 MLS
TWS 10MM WHEEL SPACER WITH LUG NUTS INSTALLED
05/29/2014 61500 MLS
ANTENNA DIVERSITY AMPLIFIER REPLACED
PART# 65209193836
06/24/2014 61700 MLS
IDLE ACTUATOR REPLACED AT BANK 2
PART# 13417834495
12/02/2014 63000 MLS
SMG HYDRAULIC PUMP MOTOR REPLACED
PART# 23017841032
SMG HYDRAULIC FUILD CHS‐11S REPLACED
SMG & SALMON RED RELAY IN DME REPLACED
PART# 61366901469 & 12631742690
04/24/2015 65000 MLS
THROTTLE BODY ACTUATOR REPLACED AT
BANK 2 PART# 13627834494
05/08/2015 65500 MLS
PENTOSIS TRANSMISSION FUILD CHANGED
SMG SACHS CLUTCH REPLACED
PART# 21212283089
CLUTCH RELEASE BEARING REPLACED
PART# 21517848830
REAR MAIN SEAL / REAR CRANKSHAFT SEAL
PART# 11217838071
CLUTCH CYLINDER SLAVE
PART# 23017838938
CLUTCH FORK LEVEL
PART# 21511223302
CLUTCH THROW‐OUT BEARING TUBE
PART# 23117564680
SPRING CLIPS
PART# 21517570284
BRONZE CLUTCH FORK PIVOT PIN
PART# 21511223328 ECSTUNING# 2608504
GREASE UNIREX S2
PART# 83239416138
REAR PASSENGER SIDE SHOCK (USED‐32K)
REPLACED PART# 33522283990
05/23/2015 65800 MLS
ALL 4 POSITION CRANKCASE VENT. REPLACED
PART# 11617836553
FUEL TANK BREATHER VALVE
PART# 13907835364
ACTIVATED CHARCOAL FUEL FILTER
PART# 16137162350
06/22/2015 65838 MLS
ROD BEARING REPLACED W/ WPC TREATMENT
X10 PART# 11247841702 (RED)
X10 PART# 11247841703 (BLUE)
ARP CONNECTING ROD BOLTS X20 ARP‐2000‐18
45 FT‐LBS TORQUE W/ ARP TORQUE LUBRICATE
VANOS INTERNAL HIGH PRESSURE HOSE
PART# 11367838669
OIL LEVEL SENSOR OIL O‐RING
PART# 12611744292
OIL PAN GASKET PART# 11137836361
OIL PUMP GASKET X2 PART# 11417836233
SUCTION/RETURN PIPE O‐RING
PART# 11121304174
ENGINE BLOCK FILTER PART# 11367834525
PART# 12137841556
FLUSH BRAKE FLUID ATE TYP 200
COMPLETELY FLUID STEERING FLUSHED
PENTOSIS HYRAULIC CHF‐11S
NEW ENGINE BREAK‐IN OIL SHELL ROTTELA T6
(5W‐40) FOR 1200 MLS.
NEW ENGINE OIL MANN FILTER HU 926/5X
X10 NEW SPARK PLUG NGK LKR‐8AP
NEW BILSTEIN FRONT SHOCK
X2 PART# 31‐231299
REPLACED SWAY BAR LINK PART# 31356758527
07/31/2015 66989 MLS
OIL CHANGED MOBIL 1 ADVANCED (0W‐40)
USED EVOSPORT PULLEY INSTALLED
08/16/2015 67466 MLS
FUEL FILTER CHANGED PART# 16117373525
08/17/2015 67496 MLS
DINAN FRONT ROLL CONTROL SYSTEM
PART# D133‐0495
DINAN 21 MM REAR SWAY BAR
DINAN URETHANE BUSHINGS
PART# D132‐0408
DINAN URETHANE GREASE
PART# 911109
08/24/2015 67700 MLS
9/24/2015 68468 MLS
9/25/2015 68514 MLS
AFE PRO DRY S AIR FILTER CLEANED
10/20/2015 69035 MLS
REPLACED OIL PRESSURRE 150 PSI SS SENDER
REPLACED FUEL PRESSURE 100 PSI SS SENDER
11/10/2015 69751 MLS
OIL CHANGED MOBIL 1 50/50 MIXED 0W‐40 AND
5W‐50. NEW ENGINE OIL MANN FILTER HU 926/5X
12/11/2015 70210 MLS
BE ROD BEARING (CLEVITE 77) REPLACED
OEM ROD BOLTS X20 PART# 11247834522
NEW ENGINE BREAK‐IN OIL MOBIL 1 (5W50)
FOR 100 MLS.
X5 NEW SPARK PLUG NGK LKR‐8AP AT BANK 1
VANOS OIL PUMP CHAIN PART# 11417834264
VANOS OIL PUMP CHAIN GUIDE RAIL
PART#11417835156
VANOS OIL PUMP TENSIONER SPRING
PART# 11417835444
VANOS OIL PUMP TENSIONER COMPRESSION
SPRING PART# 11417835445
VANOS OIL PUMP CHAIN TENSIONER GUIDE RAIL
PART# 11417837576
BUSHING PART# 11417837577
PART# 11417837578
ALL X10 BOSCH FUEL INJECTOR REPLACED
PART# 0‐280‐158‐036 (BOSCH)
PART# 13647834893 (BMW)
12/17/2015 70299 MLS
OIL CHANGED CASTROL EDGE PRO 10W‐60
02/01/2016 70983 MLS
PART# 12137841556
OIL CHANGED CASTROL EDGE PRO 6L X 10W‐60,
2.5 QTZ M1 5W50 & 2 CANS OF 300 ML LIQUI
MOLY MOS2 (600ML).
02/28/2016 71750 MLS
NEW REAR MICHELIN PILOT SUPER SPORT
05/03/2016 72457 MLS
ALL 4 VANOS SOLENOIDS REPLACED
PART# 11367841072
OIL CHANGED RED LINE 5W‐50 9 QTZ + 0.3 QTZ
RED LINE 10W‐60 AND NEW ENGINE OIL MANN
FILTER HU 926/5X
REPLACED NEW OIL LEVEL SENSOR
PART# 12617607910
REFURBISHED FRONT 2 HEADLIGHTS WITH
ZKW‐R CLEAR LENS.
FLUSHED ALL RADIATOR COOLANT WITH NEW
05/21/2016 72925 MLS
REPLACED CABIN FILTERS WITH NEW MANN
FLITERS.
REPLACED REAR WINDOW SEAL
PART# 51317027916
06/04/2016 73285 MLS
REAR DIFFERENTIAL FUILD CHANGED WITH
BMW OEM SAF‐XJ+FM BOOSTER (1.3 LTR)
AND TWO NEW DRAIN PLUGS WITH O‐RING
10/27/2016 75805 MLS
REPLACE FRONT WINDSCREEN MOUNTING
PART# 51317166841.
REPLACE 2 OF DAYCO 89133 IDLER PULLEY &
GATES 38069 TENSIONER.
11/05/2016 75948 MLS
OIL CHANGED RED LINE 5W‐50 5.5 QTZ + 4 QTZ
RED LINE 0W40 AND NEW ENGINE OIL MANN
FILTER HU 926/5X
REPLACE BOTH PRE‐CAT O2 SENSOR
PART# BOSCH 17051.
11/17/2016 76081 MLS
REPLACE VOLTAGE REGULATOR VALEO 599101
04/06/2017 79354 MLS
REPLACED NEW DURALAST H8‐AGM BATTERY
04/14/2017 79799 MLS
REPLACE FUEL PUMP BOSCH
04/23/2017 80143 MLS
REPLACE FRONT AND REAR ROTOR WITH
ZIMMERMAN (Z‐COATING / Z FORMULA)
REPLACE BRAKE LINE WITH STOPTECH
STAINLESS STEEL BRAKE LINE
FLUSH WITH NEW BRAKE FUILD ATE‐200
04/24/2017 80184 MLS
PUMP FUEL FULL TANK
04/27/2017 80234 MLS
OIL CHANGED RED LINE 5W‐50 9.5 QTZ AFTER
4,286 MLS USED. NEW ENGINE OIL MANN FILTER
HU 926/5X. NEW DIMPLE MAGNETIC OIL PLUG.
05/03/2017 80500 MLS
FUEL FILTER SENSOR REAR DRIVER SIDE PART#
16146765825. BOTH ADAPTER (LEFT & RIGHT)
PART# 16146750466. BOTH RUBBER SEALING
PART# 16146750467. REPLACE WHEEL CENTER
CAP X4 PART# 36136783536. REPLACE REAR
TRUNK EMBLEM PART# 51148132375
05/17/2017 81643 MLS
FLUSH ENTIRE A/C FLUID
07/10/2017 82889 MLS
INSTALLED NEW FUEL PRESSURE SENSOR PART#
BOSCH 0261230127 BUT STILL NOT SOLVE ERROR
CODE 27CF. INSTALLED USED IHKA AC CONTROL
UNIT AND NEW AFTERMATER WATER VALVE
HEATER PART # 64116906652 SOLVED ERROR
ERROR CODE 9C79 IHKA.
07/17/2017 83106 MLS
REPLACE STARTER PART# 12417835737 (VALEO),
EXHAUST GASKET RING PART # 11627832535,
TRANSMISSION PULSE SENSOR PART # 13627525015,
SMG RESEVOIR FILLER SCREW PART # 23017838932,
POWER STEERING RESEVOIR PART # 32412228855,
FLUSH SMG PUMP FUILD (CHF‐11S),
REPLACE TRANSMISSION FUILD (PENTOSIN MTL‐2, 3 LITER),
TRANSMISSION PUMP SEAL PART # 11417836233
EIBACH PRO‐KIT FRONT & REAR,
BOTH UPPER SPRING POCKET W/AXIAL CAGE
BEARING PART # 31331090612
07/22/2017 83190 MLS
REPLACE ENGINE OIL (2 QTY 0W20 + 7.5 QTY
5W50)
REPLACE FRONT BOTH TIRES MICHELLIN PSS
09/01/2017 84909 MLS
CORSA PERFORMANCE EXHAUST (PN# 14556)
SN# 082417‐140409 (LEFT)
SN# 082217‐154512 (RIGHT)
10/05/2017 86222 MLS
REPLACE ENGINE OIL (9.5 QTY 0W40)
AFTER 3,032 MLS
10/29/2017 87400 MLS
REPLACE ALTERNATOR BELT
CONTINENTAL ELITE PART# 4060550
REPLACE A/C BELT
CONTINENTAL ELITE PART# 4060407
11/12/2017 88031 MLS
SWITCHED WINTER TIRE PIRELLI SOTOZERO
02/12/2018 89618 MLS
REPLACE ENGINE OIL (7.5 QTY 0W40 +
2 QTY 0W20). AFTER 3,396 MLS USED.
05/07/2018 91420 MLS
CHANGED TO SUMMER TIRES
REPLACE BOTH REAR NEW SHOCK BILSTEIN B6
BILSTEIN PART # 26‐231303
05/20/2018 91730 MLS
REPLACE SECONDARY PUMP (11727571589)
EVAP PUMP MASS AIR FLOW SENSOR (11721438814)
REPLACE THERMOSTAT (11537836155)
REPLACE AUXILIARY FAN SWITCH (13621433077)
BOTH SIDE TIE ROD ASSEMBLY (32106777479)
BOTH RUBBER BOOT (32102454428)
UPPER CONTROL ARM RIGHT (31102348046)
UPPER CONTROL ARM LEFT (31102348047)
UPPER CONTROL ARM POWERFLEX BUSHS (PFF5‐701X2)
LOWER WISHBONE LEFT (31122347963)
LOWER WISHBONE RIGHT (31122347965)
LOWER WISHBONE POWERFLEX BUSHS (PFF5‐1002X2)
REAR GUIDING SUSPENSION LINK LEFT (33322283771)
REPLACE STEERING GEAR COVER LEFT (51717906521)
REPLACE STEERING GEAR COVER RIGHT (51717906522)
REPLACE BOTH FRONT UPPER SPRING PAD (31331091233)
REPLACE BOTH FRONT LOWER SPRING PAD (31331096664)
REPLACE FRONT BOTH HEADLIGHT AND RETROFIT EVOR‐X
REPLACE HID OSRAM CBB BULB
REPLACE 55W MORIMOTO BALLAST
FLUSH NEW COOLANT (5 LITRES)
05/26/2018 91893 MLS
REPLACE ENGINE OIL (7.5 QTY 5W50 +
2 QTY 0W20). AFTER 2,275 MLS USED.
06/01/2018 91900 MLS
NEW LOLIPOP RED W/ SILVER POWDER COATING
NEW 57MM CONVERSION STUDS & PROJECT KICS
LEGGDURA 53MM 2 PIECES GOLD COVER LUG NUT
06/22/2018 92370 MLS
NEW BOTH STABILIZER BAR LINK
PART# 31306781547–LEFT & 31306781548‐RIGHT
NEW BOTH STABILIZER BAR MOUNT (31352283071)
NEW STEERING RACK ZF‐BOSCH (32102283767
OR BOSCH PART# KS01000938)
FLUSH STEERING FUILD 1 LITRE W/ CHF‐11S
NEW BOTH FRONT STRUT UPPER MOUNT
PART# 31332282651
BOTH UPPER SPRING POCKET W/AXIAL CAGE BEARING
PART# 31331090612
06/27/2018 92520 MLS
X2 PART# 31‐231299
07/03/2018 92770 MLS
TUNER MOTOSPORT MONOBALL LOWER
AND UPPER CONTROL ARM
REPLACE BOTH FRONT WHEEL BEARING FAG
BRAND. BMW PART # 31222282670
ALL BRAKES SERVICE WITH CRC QUIET AND
PERMATEX SILICON CERAMIC EXTREME BRAKE
GREASE.
CONVERT WHEEL STUD WITH H&R 40MM
THREAD LENGTH QUICK‐SAFE CONVERSION STUD
07/06/2018 92820 MLS
08/31/2018 94369 MLS
REPLACE STEERING LOWER JOINT SHAFT
ASSEMBLY STEERING RACK PART# 32306780893
REPLACE TWO TORX BOLTS PART# 32306778609
WITH LOCTITE 2422 HIGH TEMPERATURE
09/29/2018 94786 MLS
REPLACE ENGINE OIL (9.5 QTY 0W40).
AFTER 2,893 MLS USED.
09/30/2018 94831 MLS
AFTER 21,546 MLS USED.
10/02/2018 94896 MLS
REPLACE X10 NEW SPARK PLUG NGK LKR‐8AP
AFTER 24686 MLS USED
REPLACE 2 POSITION CRANKCASE VENTILATION
PART# 11617836553. AFTER 29096 MLS USED
01/27/2019 97317 MLS
REPLACE ENGINE OIL (7.5 QTZ 0W40
+ 2 QTZ 0W20) AFTER 2,531 MLS USED.
04/19/2019 98899 MLS
05/02/2019 99340 MLS
REPLACE O‐RING PART # 11427832782 X 2
REPLACE O‐RING PART # 17222245358 X 2
OIL FILTER COVER PART # 11427834730
06/14/2019 100142 MLS
2 QTY 0W20). AFTER 2,825 MLS USED.
08/01/2019 101148 MLS
REPLACE X1 IGNITION COIL AT CYL. 2
PART# 12137841556
11/21/2019 102971 MLS
REPLACE WITH NEW IDLE ACTUATOR AT BANK 1
PART # 13417834495.
REPLACE GASKET BOTH BANK 1 AND 2 PART #
13417836405.
REPLACE O‐RING AT BANK 2 PART # 13417834429
12/12/2019 103368 MLS
2 QTY 0W20). AFTER 3,226 MLS USED.
939135
939137
939138
939139
939140
939141
939142
939143
939144
1 - 3 of 3 Posts
