1 - 17 of 17 Posts
Yes. Excessive oil will foul the MAFs.
First I heard of this was on Rennlist (Porsche) many years ago. I figure if those oil filters really did help generate more horsepower, the cars would come that way from the factory.
And then you have the fine particulate filtering of the K&N's vs. paper.
Sure K&N's flow more but also allow more dirty air through.
There was a post years back where a guy in a miata did this fairly comprehensive filter comparison in an Urban area.
The results were quite surprising. You would think that there would be no issue running K&N in a city environment, but they definately let more dirt through than paper.
Now - this wasn't super scientific, but the pictures were interesting enough.
Then there was another article that put in a bunch of filters during dyno runs.
They found that the gains were pretty insignificant -
That said - many people run K&N with no ill effects. Probably because the particulate size is small enough not to cause any issues.
I have K&N's for the stock OEM filter housings, but run paper when I was having issues chasing horsepower.
I think you don't need to worry about the MAF's if they are properly oiled and allowed to sit before putting into use.
Even with the ALPHA-N - I am hesitant to put these filters in.
I'd prefer to feed the S62 with clean air consistantly. Paper filters are cheap, S62's are not.
Paper filters are so darn cheap...no reason not to spend 30 bucks a year on filters to not even have to worry about fouling the MAFS
Go for AFE Pro Dry S filters. They are oil less but cleanable/reusable and offer a tad more flow over paper filters.
I have always run a K&N in my car with no issues and 185k miles on the odometer. I have a spare K&N filter that I clean, dry and then re-oil. I let it set overnight before swapping it with the dirty one. Oil analysis shows no evidence of dirt getting past the filter.
K&N vs. MAF
what if u have put K&N filters in....... do u need to spray in a cleaner to clean of the oil ? I put in some right out of the box. did I screw up my MAFn sensors ?????????:eek:
1 - 17 of 17 Posts
