1 - 8 of 8 Posts
dear all
Hope all well.
I was driving normally and I got 2B57 fault code. Dealership said its mass air flow sensor or secondary air pump (changed both) no cure. I am sure now dealership doesn't know what they are doing.
Can some please help me, I am in trouble with this code the cluster says engine fault reduced power.
Many thanks... :(
2b57 means motor emergency program and is never found by itself. There has to be another code stores which causes that one.
Your problem is with your DMTL (Diagnostic Monitoring-Tank Leakage) pump which draws a vacuum on the gas tank. It's a cheap component to replace. Left rear wheel well.
1 - 8 of 8 Posts
