Fault Code: 002B59 - Coolant thermostat monitoring (log attached)
4K views 9 replies 2 participants last post by  J.R ///M5
#1 · (Edited)
No check engine light.
(Apologize in advance...couldn’t attach the log file so it was readable.)
So I’m trying to track down a couple codes. I’m not getting a check engine light but when I scan codes I’m getting this 002B59 “cooler outlet temp is 0 degrees” thermostat error that shows. My needle when warmed up is a hair lower than the middle line on the temp gauge. Never seems to go above it. I get heat and A/C fine. Took about a 10 min drive to warm the car up....shut it down for 5 mins...then started it back up and logged about a 10 min drive and then sat in my driveway for a few while I ran this test (reason for temps drop at the end) Do these temps look normal? Could this be a bad thermostat, sensor, or iCarly false positive?
04.04.2020 20:47:11 Coolant outlet temperature (°C) Battery voltage (V) Measured Battery Voltage From lbs (V manuell) coolant (°C) noParameterSelected noParameterSelected
04.04.2020 20:47:04 44.100006 13.600000 14.000000 44.100006 0 0
04.04.2020 20:47:14 41.199982 13.700000 14.005000 41.199982 0 0
04.04.2020 20:47:15 41.399994 13.600000 14.008000 41.399994 0 0
04.04.2020 20:47:17 41.399994 13.600000 14.003000 41.399994 0 0
04.04.2020 20:47:18 41.399994 13.700000 14.012000 41.399994 0 0
04.04.2020 20:47:19 41.500000 13.600000 14.008000 41.500000 0 0
04.04.2020 20:47:20 41.600006 13.700000 14.007000 41.600006 0 0
04.04.2020 20:47:22 41.799988 13.700000 14.008000 41.799988 0 0
06.04.2020 17:59:53 Coolant outlet temperature (°C) coolant (°C) noParameterSelected noParameterSelected noParameterSelected noParameterSelected
06.04.2020 17:59:53 70.699982 70.699982 0 0 0 0
06.04.2020 17:59:54 70.799988 70.799988 0 0 0 0
06.04.2020 17:59:55 70.799988 70.799988 0 0 0 0
06.04.2020 17:59:56 70.899994 70.899994 0 0 0 0
06.04.2020 17:59:56 71.000000 71.000000 0 0 0 0
06.04.2020 17:59:57 71.000000 71.000000 0 0 0 0
06.04.2020 17:59:58 71.100006 71.100006 0 0 0 0
06.04.2020 17:59:58 71.199982 71.199982 0 0 0 0
06.04.2020 17:59:59 71.299988 71.299988 0 0 0 0
06.04.2020 18:00:00 71.299988 71.299988 0 0 0 0
06.04.2020 18:00:01 71.299988 71.299988 0 0 0 0
06.04.2020 18:00:01 71.199982 71.199982 0 0 0 0
06.04.2020 18:00:02 71.199982 71.199982 0 0 0 0
06.04.2020 18:00:03 71.299988 71.299988 0 0 0 0
06.04.2020 18:00:04 71.399994 71.399994 0 0 0 0
06.04.2020 18:00:05 71.600006 71.600006 0 0 0 0
06.04.2020 18:00:07 71.699982 71.699982 0 0 0 0
06.04.2020 18:00:08 71.899994 71.899994 0 0 0 0
06.04.2020 18:00:10 72.000000 72.000000 0 0 0 0
06.04.2020 18:00:12 72.000000 72.000000 0 0 0 0
06.04.2020 18:00:12 72.199982 72.199982 0 0 0 0
06.04.2020 18:00:14 72.199982 72.199982 0 0 0 0
06.04.2020 18:00:16 72.299988 72.299988 0 0 0 0
06.04.2020 18:00:18 72.299988 72.299988 0 0 0 0
06.04.2020 18:00:19 72.299988 72.299988 0 0 0 0
06.04.2020 18:00:20 72.299988 72.299988 0 0 0 0
06.04.2020 18:00:21 72.299988 72.299988 0 0 0 0
06.04.2020 18:00:22 72.299988 72.299988 0 0 0 0
06.04.2020 18:00:23 72.299988 72.299988 0 0 0 0
06.04.2020 18:00:24 72.299988 72.299988 0 0 0 0
06.04.2020 18:00:25 72.500000 72.500000 0 0 0 0
06.04.2020 18:00:26 72.600006 72.600006 0 0 0 0
06.04.2020 18:00:27 72.699982 72.699982 0 0 0 0
06.04.2020 18:00:27 72.799988 72.799988 0 0 0 0
06.04.2020 18:00:28 72.899994 72.899994 0 0 0 0
06.04.2020 18:00:29 72.899994 72.899994 0 0 0 0
06.04.2020 18:00:30 72.899994 72.899994 0 0 0 0
06.04.2020 18:00:30 73.000000 73.000000 0 0 0 0
06.04.2020 18:00:31 73.000000 73.000000 0 0 0 0
06.04.2020 18:00:32 72.899994 72.899994 0 0 0 0
06.04.2020 18:00:32 73.000000 73.000000 0 0 0 0
06.04.2020 18:00:33 73.000000 73.000000 0 0 0 0
06.04.2020 18:00:34 73.000000 73.000000 0 0 0 0
06.04.2020 18:00:35 73.100006 73.100006 0 0 0 0
06.04.2020 18:00:35 73.199982 73.199982 0 0 0 0
06.04.2020 18:00:36 73.299988 73.299988 0 0 0 0
06.04.2020 18:00:37 73.399994 73.399994 0 0 0 0
06.04.2020 18:00:38 73.500000 73.500000 0 0 0 0
06.04.2020 18:00:39 73.500000 73.500000 0 0 0 0
06.04.2020 18:00:40 73.600006 73.600006 0 0 0 0
06.04.2020 18:00:41 73.600006 73.600006 0 0 0 0
06.04.2020 18:00:42 73.600006 73.600006 0 0 0 0
06.04.2020 18:00:42 73.699982 73.699982 0 0 0 0
06.04.2020 18:00:43 73.699982 73.699982 0 0 0 0
06.04.2020 18:00:44 73.799988 73.799988 0 0 0 0
06.04.2020 18:00:45 73.799988 73.799988 0 0 0 0
06.04.2020 18:00:45 73.699982 73.699982 0 0 0 0
06.04.2020 18:00:46 73.799988 73.799988 0 0 0 0
06.04.2020 18:00:47 73.699982 73.699982 0 0 0 0
06.04.2020 18:00:48 73.699982 73.699982 0 0 0 0
06.04.2020 18:00:48 73.799988 73.799988 0 0 0 0
06.04.2020 18:00:49 73.899994 73.899994 0 0 0 0
06.04.2020 18:00:50 73.899994 73.899994 0 0 0 0
06.04.2020 18:00:51 73.899994 73.899994 0 0 0 0
06.04.2020 18:00:52 73.899994 73.899994 0 0 0 0
06.04.2020 18:00:53 73.899994 73.899994 0 0 0 0
06.04.2020 18:00:53 74.000000 74.000000 0 0 0 0
06.04.2020 18:00:54 74.100006 74.100006 0 0 0 0
06.04.2020 18:00:55 74.199982 74.199982 0 0 0 0
06.04.2020 18:00:55 74.100006 74.100006 0 0 0 0
06.04.2020 18:00:56 74.199982 74.199982 0 0 0 0
06.04.2020 18:00:57 74.199982 74.199982 0 0 0 0
06.04.2020 18:00:58 74.199982 74.199982 0 0 0 0
06.04.2020 18:00:59 74.299988 74.299988 0 0 0 0
06.04.2020 18:01:00 74.399994 74.399994 0 0 0 0
06.04.2020 18:01:01 74.399994 74.399994 0 0 0 0
06.04.2020 18:01:02 74.500000 74.500000 0 0 0 0
06.04.2020 18:01:03 74.600006 74.600006 0 0 0 0
06.04.2020 18:01:04 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:05 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:06 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:07 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:08 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:09 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:09 74.799988 74.799988 0 0 0 0
06.04.2020 18:01:10 74.899994 74.899994 0 0 0 0
06.04.2020 18:01:11 74.799988 74.799988 0 0 0 0
06.04.2020 18:01:12 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:13 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:14 74.799988 74.799988 0 0 0 0
06.04.2020 18:01:15 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:16 74.600006 74.600006 0 0 0 0
06.04.2020 18:01:17 74.600006 74.600006 0 0 0 0
06.04.2020 18:01:18 74.600006 74.600006 0 0 0 0
06.04.2020 18:01:19 74.600006 74.600006 0 0 0 0
06.04.2020 18:01:20 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:21 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:22 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:23 74.799988 74.799988 0 0 0 0
06.04.2020 18:01:24 74.899994 74.899994 0 0 0 0
06.04.2020 18:01:25 75.000000 75.000000 0 0 0 0
06.04.2020 18:01:26 75.000000 75.000000 0 0 0 0
06.04.2020 18:01:27 75.100006 75.100006 0 0 0 0
06.04.2020 18:01:28 75.100006 75.100006 0 0 0 0
06.04.2020 18:01:29 75.100006 75.100006 0 0 0 0
06.04.2020 18:01:30 74.899994 74.899994 0 0 0 0
06.04.2020 18:01:31 74.899994 74.899994 0 0 0 0
06.04.2020 18:01:32 74.899994 74.899994 0 0 0 0
06.04.2020 18:01:33 75.000000 75.000000 0 0 0 0
06.04.2020 18:01:34 75.000000 75.000000 0 0 0 0
06.04.2020 18:01:35 75.199982 75.199982 0 0 0 0
06.04.2020 18:01:36 75.199982 75.199982 0 0 0 0
06.04.2020 18:01:37 75.199982 75.199982 0 0 0 0
06.04.2020 18:01:38 75.299988 75.299988 0 0 0 0
06.04.2020 18:01:39 75.199982 75.199982 0 0 0 0
06.04.2020 18:01:40 75.199982 75.199982 0 0 0 0
06.04.2020 18:01:41 75.199982 75.199982 0 0 0 0
06.04.2020 18:01:41 75.100006 75.100006 0 0 0 0
06.04.2020 18:01:42 75.000000 75.000000 0 0 0 0
06.04.2020 18:01:43 74.899994 74.899994 0 0 0 0
06.04.2020 18:01:44 74.899994 74.899994 0 0 0 0
06.04.2020 18:01:45 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:46 74.699982 74.699982 0 0 0 0
06.04.2020 18:01:47 74.500000 74.500000 0 0 0 0
06.04.2020 18:01:47 74.399994 74.399994 0 0 0 0
06.04.2020 18:01:48 74.199982 74.199982 0 0 0 0
06.04.2020 18:01:49 74.000000 74.000000 0 0 0 0
06.04.2020 18:01:50 73.799988 73.799988 0 0 0 0
06.04.2020 18:01:50 73.500000 73.500000 0 0 0 0
06.04.2020 18:01:52 73.500000 73.500000 0 0 0 0
06.04.2020 18:01:53 73.399994 73.399994 0 0 0 0
06.04.2020 18:01:53 73.500000 73.500000 0 0 0 0
06.04.2020 18:01:54 73.500000 73.500000 0 0 0 0
06.04.2020 18:01:55 73.600006 73.600006 0 0 0 0
06.04.2020 18:01:56 73.699982 73.699982 0 0 0 0
06.04.2020 18:01:56 73.899994 73.899994 0 0 0 0
06.04.2020 18:01:57 74.000000 74.000000 0 0 0 0
06.04.2020 18:01:58 74.199982 74.199982 0 0 0 0
06.04.2020 18:01:59 74.399994 74.399994 0 0 0 0
06.04.2020 18:02:00 74.500000 74.500000 0 0 0 0
06.04.2020 18:02:01 74.600006 74.600006 0 0 0 0
06.04.2020 18:02:02 74.699982 74.699982 0 0 0 0
06.04.2020 18:02:03 74.699982 74.699982 0 0 0 0
06.04.2020 18:02:04 74.699982 74.699982 0 0 0 0
06.04.2020 18:02:05 74.699982 74.699982 0 0 0 0
06.04.2020 18:02:06 74.799988 74.799988 0 0 0 0
06.04.2020 18:02:07 74.699982 74.699982 0 0 0 0
06.04.2020 18:02:08 74.600006 74.600006 0 0 0 0
06.04.2020 18:02:09 74.600006 74.600006 0 0 0 0
06.04.2020 18:02:10 74.600006 74.600006 0 0 0 0
06.04.2020 18:02:10 74.699982 74.699982 0 0 0 0
06.04.2020 18:02:11 74.799988 74.799988 0 0 0 0
06.04.2020 18:02:12 74.899994 74.899994 0 0 0 0
06.04.2020 18:02:13 74.899994 74.899994 0 0 0 0
06.04.2020 18:02:13 74.799988 74.799988 0 0 0 0
06.04.2020 18:02:14 74.899994 74.899994 0 0 0 0
06.04.2020 18:02:15 74.799988 74.799988 0 0 0 0
06.04.2020 18:02:16 74.799988 74.799988 0 0 0 0
06.04.2020 18:02:17 74.799988 74.799988 0 0 0 0
06.04.2020 18:02:18 74.699982 74.699982 0 0 0 0
06.04.2020 18:02:18 74.799988 74.799988 0 0 0 0
06.04.2020 18:02:19 74.799988 74.799988 0 0 0 0
06.04.2020 18:02:20 74.699982 74.699982 0 0 0 0
06.04.2020 18:02:20 74.600006 74.600006 0 0 0 0
06.04.2020 18:02:21 74.600006 74.600006 0 0 0 0
06.04.2020 18:02:22 74.399994 74.399994 0 0 0 0
06.04.2020 18:02:23 74.399994 74.399994 0 0 0 0
06.04.2020 18:02:23 74.299988 74.299988 0 0 0 0
06.04.2020 18:02:24 74.199982 74.199982 0 0 0 0
06.04.2020 18:02:25 74.100006 74.100006 0 0 0 0
06.04.2020 18:02:26 74.000000 74.000000 0 0 0 0
06.04.2020 18:02:27 73.799988 73.799988 0 0 0 0
06.04.2020 18:02:28 73.699982 73.699982 0 0 0 0
06.04.2020 18:02:28 73.600006 73.600006 0 0 0 0
06.04.2020 18:02:29 73.600006 73.600006 0 0 0 0
06.04.2020 18:02:30 73.600006 73.600006 0 0 0 0
06.04.2020 18:02:31 73.699982 73.699982 0 0 0 0
06.04.2020 18:02:31 73.799988 73.799988 0 0 0 0
06.04.2020 18:02:32 73.899994 73.899994 0 0 0 0
06.04.2020 18:02:33 74.000000 74.000000 0 0 0 0
06.04.2020 18:02:34 74.100006 74.100006 0 0 0 0
06.04.2020 18:02:34 74.199982 74.199982 0 0 0 0
06.04.2020 18:02:35 74.299988 74.299988 0 0 0 0
06.04.2020 18:02:36 74.399994 74.399994 0 0 0 0
06.04.2020 18:02:37 74.399994 74.399994 0 0 0 0
06.04.2020 18:02:38 74.500000 74.500000 0 0 0 0
06.04.2020 18:02:39 74.600006 74.600006 0 0 0 0
06.04.2020 18:02:40 74.600006 74.600006 0 0 0 0
06.04.2020 18:02:41 74.799988 74.799988 0 0 0 0
06.04.2020 18:02:41 74.899994 74.899994 0 0 0 0
06.04.2020 18:02:42 74.899994 74.899994 0 0 0 0
06.04.2020 18:02:43 75.100006 75.100006 0 0 0 0
06.04.2020 18:02:44 75.100006 75.100006 0 0 0 0
06.04.2020 18:02:45 75.100006 75.100006 0 0 0 0
06.04.2020 18:02:46 75.100006 75.100006 0 0 0 0
06.04.2020 18:02:46 75.199982 75.199982 0 0 0 0
06.04.2020 18:02:47 75.199982 75.199982 0 0 0 0
06.04.2020 18:02:48 75.100006 75.100006 0 0 0 0
06.04.2020 18:02:49 75.199982 75.199982 0 0 0 0
06.04.2020 18:02:50 75.199982 75.199982 0 0 0 0
06.04.2020 18:02:51 75.100006 75.100006 0 0 0 0
06.04.2020 18:02:51 75.199982 75.199982 0 0 0 0
06.04.2020 18:02:52 75.199982 75.199982 0 0 0 0
06.04.2020 18:02:53 75.100006 75.100006 0 0 0 0
06.04.2020 18:02:54 75.100006 75.100006 0 0 0 0
06.04.2020 18:02:55 75.000000 75.000000 0 0 0 0
06.04.2020 18:02:56 75.000000 75.000000 0 0 0 0
06.04.2020 18:02:57 75.000000 75.000000 0 0 0 0
06.04.2020 18:02:58 74.899994 74.899994 0 0 0 0
06.04.2020 18:02:59 75.000000 75.000000 0 0 0 0
06.04.2020 18:03:00 75.000000 75.000000 0 0 0 0
06.04.2020 18:03:01 75.000000 75.000000 0 0 0 0
06.04.2020 18:03:02 75.000000 75.000000 0 0 0 0
06.04.2020 18:03:03 75.100006 75.100006 0 0 0 0
06.04.2020 18:03:03 75.199982 75.199982 0 0 0 0
06.04.2020 18:03:04 75.399994 75.399994 0 0 0 0
06.04.2020 18:03:05 75.399994 75.399994 0 0 0 0
06.04.2020 18:03:06 75.500000 75.500000 0 0 0 0
06.04.2020 18:03:06 75.600006 75.600006 0 0 0 0
06.04.2020 18:03:07 75.600006 75.600006 0 0 0 0
06.04.2020 18:03:08 75.600006 75.600006 0 0 0 0
06.04.2020 18:03:09 75.699982 75.699982 0 0 0 0
06.04.2020 18:03:10 75.600006 75.600006 0 0 0 0
06.04.2020 18:03:11 75.600006 75.600006 0 0 0 0
06.04.2020 18:03:12 75.699982 75.699982 0 0 0 0
06.04.2020 18:03:13 75.699982 75.699982 0 0 0 0
06.04.2020 18:03:14 75.699982 75.699982 0 0 0 0
06.04.2020 18:03:15 75.799988 75.799988 0 0 0 0
06.04.2020 18:03:16 75.899994 75.899994 0 0 0 0
06.04.2020 18:03:17 75.899994 75.899994 0 0 0 0
06.04.2020 18:03:18 75.899994 75.899994 0 0 0 0
06.04.2020 18:03:19 76.000000 76.000000 0 0 0 0
06.04.2020 18:03:20 76.000000 76.000000 0 0 0 0
06.04.2020 18:03:21 76.000000 76.000000 0 0 0 0
06.04.2020 18:03:22 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:22 76.000000 76.000000 0 0 0 0
06.04.2020 18:03:23 76.000000 76.000000 0 0 0 0
06.04.2020 18:03:24 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:25 76.000000 76.000000 0 0 0 0
06.04.2020 18:03:25 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:26 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:27 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:28 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:29 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:30 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:30 76.199982 76.199982 0 0 0 0
06.04.2020 18:03:31 76.199982 76.199982 0 0 0 0
06.04.2020 18:03:32 76.299988 76.299988 0 0 0 0
06.04.2020 18:03:33 76.299988 76.299988 0 0 0 0
06.04.2020 18:03:34 76.299988 76.299988 0 0 0 0
06.04.2020 18:03:35 76.299988 76.299988 0 0 0 0
06.04.2020 18:03:36 76.199982 76.199982 0 0 0 0
06.04.2020 18:03:37 76.199982 76.199982 0 0 0 0
06.04.2020 18:03:37 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:38 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:39 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:40 76.000000 76.000000 0 0 0 0
06.04.2020 18:03:40 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:41 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:42 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:43 76.000000 76.000000 0 0 0 0
06.04.2020 18:03:44 76.199982 76.199982 0 0 0 0
06.04.2020 18:03:45 76.199982 76.199982 0 0 0 0
06.04.2020 18:03:45 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:46 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:47 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:48 76.100006 76.100006 0 0 0 0
06.04.2020 18:03:48 76.199982 76.199982 0 0 0 0
06.04.2020 18:03:49 76.199982 76.199982 0 0 0 0
06.04.2020 18:03:50 76.299988 76.299988 0 0 0 0
06.04.2020 18:03:51 76.299988 76.299988 0 0 0 0
06.04.2020 18:03:52 76.399994 76.399994 0 0 0 0
06.04.2020 18:03:53 76.399994 76.399994 0 0 0 0
06.04.2020 18:03:54 76.399994 76.399994 0 0 0 0
06.04.2020 18:03:55 76.500000 76.500000 0 0 0 0
06.04.2020 18:03:56 76.500000 76.500000 0 0 0 0
06.04.2020 18:03:57 76.399994 76.399994 0 0 0 0
06.04.2020 18:03:58 76.399994 76.399994 0 0 0 0
06.04.2020 18:03:59 76.500000 76.500000 0 0 0 0
06.04.2020 18:04:00 76.399994 76.399994 0 0 0 0
06.04.2020 18:04:01 76.399994 76.399994 0 0 0 0
06.04.2020 18:04:02 76.399994 76.399994 0 0 0 0
06.04.2020 18:04:03 76.399994 76.399994 0 0 0 0
06.04.2020 18:04:04 76.399994 76.399994 0 0 0 0
06.04.2020 18:04:05 76.299988 76.299988 0 0 0 0
06.04.2020 18:04:06 76.299988 76.299988 0 0 0 0
06.04.2020 18:04:07 76.299988 76.299988 0 0 0 0
06.04.2020 18:04:08 76.299988 76.299988 0 0 0 0
06.04.2020 18:04:09 76.399994 76.399994 0 0 0 0
06.04.2020 18:04:10 76.399994 76.399994 0 0 0 0
06.04.2020 18:04:11 76.299988 76.299988 0 0 0 0
06.04.2020 18:04:11 76.199982 76.199982 0 0 0 0
06.04.2020 18:04:12 76.100006 76.100006 0 0 0 0
06.04.2020 18:04:13 76.000000 76.000000 0 0 0 0
06.04.2020 18:04:14 75.899994 75.899994 0 0 0 0
06.04.2020 18:04:15 76.000000 76.000000 0 0 0 0
06.04.2020 18:04:16 76.199982 76.199982 0 0 0 0
06.04.2020 18:04:16 76.299988 76.299988 0 0 0 0
06.04.2020 18:04:17 76.299988 76.299988 0 0 0 0
06.04.2020 18:04:18 76.299988 76.299988 0 0 0 0
06.04.2020 18:04:18 76.100006 76.100006 0 0 0 0
06.04.2020 18:04:19 75.899994 75.899994 0 0 0 0
06.04.2020 18:04:20 75.699982 75.699982 0 0 0 0
06.04.2020 18:04:20 75.600006 75.600006 0 0 0 0
06.04.2020 18:04:21 75.399994 75.399994 0 0 0 0
06.04.2020 18:04:22 75.500000 75.500000 0 0 0 0
06.04.2020 18:04:23 75.699982 75.699982 0 0 0 0
06.04.2020 18:04:23 75.799988 75.799988 0 0 0 0
06.04.2020 18:04:24 76.000000 76.000000 0 0 0 0
06.04.2020 18:04:25 76.199982 76.199982 0 0 0 0
06.04.2020 18:04:25 76.399994 76.399994 0 0 0 0
06.04.2020 18:04:26 76.600006 76.600006 0 0 0 0
06.04.2020 18:04:27 76.799988 76.799988 0 0 0 0
06.04.2020 18:04:28 76.899994 76.899994 0 0 0 0
06.04.2020 18:04:28 77.100006 77.100006 0 0 0 0
06.04.2020 18:04:29 77.100006 77.100006 0 0 0 0
06.04.2020 18:04:30 77.100006 77.100006 0 0 0 0
06.04.2020 18:04:30 77.299988 77.299988 0 0 0 0
06.04.2020 18:04:31 77.299988 77.299988 0 0 0 0
06.04.2020 18:04:32 77.299988 77.299988 0 0 0 0
06.04.2020 18:04:33 77.399994 77.399994 0 0 0 0
06.04.2020 18:04:34 77.399994 77.399994 0 0 0 0
06.04.2020 18:04:35 77.399994 77.399994 0 0 0 0
06.04.2020 18:04:36 77.399994 77.399994 0 0 0 0
06.04.2020 18:04:37 77.399994 77.399994 0 0 0 0
06.04.2020 18:04:38 77.399994 77.399994 0 0 0 0
06.04.2020 18:04:39 77.399994 77.399994 0 0 0 0
06.04.2020 18:04:40 77.299988 77.299988 0 0 0 0
06.04.2020 18:04:41 77.299988 77.299988 0 0 0 0
06.04.2020 18:04:42 77.299988 77.299988 0 0 0 0
06.04.2020 18:04:42 77.100006 77.100006 0 0 0 0
06.04.2020 18:04:43 77.000000 77.000000 0 0 0 0
06.04.2020 18:04:44 76.899994 76.899994 0 0 0 0
06.04.2020 18:04:44 76.699982 76.699982 0 0 0 0
06.04.2020 18:04:45 76.500000 76.500000 0 0 0 0
06.04.2020 18:04:46 76.299988 76.299988 0 0 0 0
06.04.2020 18:04:47 75.899994 75.899994 0 0 0 0
06.04.2020 18:04:47 75.600006 75.600006 0 0 0 0
06.04.2020 18:04:48 75.299988 75.299988 0 0 0 0
06.04.2020 18:04:49 75.000000 75.000000 0 0 0 0
06.04.2020 18:04:49 74.799988 74.799988 0 0 0 0
06.04.2020 18:04:50 74.299988 74.299988 0 0 0 0
06.04.2020 18:04:51 73.699982 73.699982 0 0 0 0
06.04.2020 18:04:51 73.199982 73.199982 0 0 0 0
06.04.2020 18:04:52 72.500000 72.500000 0 0 0 0
06.04.2020 18:04:53 71.899994 71.899994 0 0 0 0
06.04.2020 18:04:53 71.100006 71.100006 0 0 0 0
06.04.2020 18:04:54 70.399994 70.399994 0 0 0 0
06.04.2020 18:04:55 69.500000 69.500000 0 0 0 0
06.04.2020 18:04:56 68.699982 68.699982 0 0 0 0
06.04.2020 18:04:56 67.799988 67.799988 0 0 0 0
06.04.2020 18:04:57 67.000000 67.000000 0 0 0 0
06.04.2020 18:04:58 66.399994 66.399994 0 0 0 0
06.04.2020 18:04:58 66.000000 66.000000 0 0 0 0
06.04.2020 18:04:59 65.500000 65.500000 0 0 0 0
06.04.2020 18:05:00 65.399994 65.399994 0 0 0 0
06.04.2020 18:05:00 66.000000 66.000000 0 0 0 0
06.04.2020 18:05:01 67.199982 67.199982 0 0 0 0
06.04.2020 18:05:02 68.799988 68.799988 0 0 0 0
06.04.2020 18:05:03 70.600006 70.600006 0 0 0 0
06.04.2020 18:05:03 72.299988 72.299988 0 0 0 0
06.04.2020 18:05:04 73.500000 73.500000 0 0 0 0
06.04.2020 18:05:05 74.500000 74.500000 0 0 0 0
06.04.2020 18:05:05 75.399994 75.399994 0 0 0 0
06.04.2020 18:05:06 75.899994 75.899994 0 0 0 0
06.04.2020 18:05:07 76.399994 76.399994 0 0 0 0
06.04.2020 18:05:08 76.699982 76.699982 0 0 0 0
06.04.2020 18:05:08 77.000000 77.000000 0 0 0 0
06.04.2020 18:05:09 77.199982 77.199982 0 0 0 0
06.04.2020 18:05:10 77.399994 77.399994 0 0 0 0
06.04.2020 18:05:10 77.600006 77.600006 0 0 0 0
06.04.2020 18:05:11 77.699982 77.699982 0 0 0 0
06.04.2020 18:05:12 77.899994 77.899994 0 0 0 0
06.04.2020 18:05:13 78.000000 78.000000 0 0 0 0
06.04.2020 18:05:14 78.000000 78.000000 0 0 0 0
06.04.2020 18:05:15 77.899994 77.899994 0 0 0 0
06.04.2020 18:05:16 77.799988 77.799988 0 0 0 0
06.04.2020 18:05:17 77.799988 77.799988 0 0 0 0
06.04.2020 18:05:18 77.799988 77.799988 0 0 0 0
06.04.2020 18:05:19 77.699982 77.699982 0 0 0 0
06.04.2020 18:05:20 77.600006 77.600006 0 0 0 0
06.04.2020 18:05:20 77.500000 77.500000 0 0 0 0
06.04.2020 18:05:21 77.399994 77.399994 0 0 0 0
06.04.2020 18:05:22 77.399994 77.399994 0 0 0 0
06.04.2020 18:05:23 77.299988 77.299988 0 0 0 0
06.04.2020 18:05:23 77.199982 77.199982 0 0 0 0
06.04.2020 18:05:24 77.100006 77.100006 0 0 0 0
06.04.2020 18:05:25 77.199982 77.199982 0 0 0 0
06.04.2020 18:05:26 77.299988 77.299988 0 0 0 0
06.04.2020 18:05:27 77.399994 77.399994 0 0 0 0
06.04.2020 18:05:27 77.500000 77.500000 0 0 0 0
06.04.2020 18:05:28 77.699982 77.699982 0 0 0 0
06.04.2020 18:05:29 77.799988 77.799988 0 0 0 0
06.04.2020 18:05:29 77.899994 77.899994 0 0 0 0
06.04.2020 18:05:30 77.899994 77.899994 0 0 0 0
06.04.2020 18:05:31 78.000000 78.000000 0 0 0 0
06.04.2020 18:05:32 78.000000 78.000000 0 0 0 0
06.04.2020 18:05:33 77.899994 77.899994 0 0 0 0
06.04.2020 18:05:34 77.799988 77.799988 0 0 0 0
06.04.2020 18:05:35 77.799988 77.799988 0 0 0 0
06.04.2020 18:05:35 77.699982 77.699982 0 0 0 0
06.04.2020 18:05:36 77.699982 77.699982 0 0 0 0
06.04.2020 18:05:37 77.600006 77.600006 0 0 0 0
06.04.2020 18:05:37 77.699982 77.699982 0 0 0 0
06.04.2020 18:05:38 77.600006 77.600006 0 0 0 0
06.04.2020 18:05:39 77.600006 77.600006 0 0 0 0
06.04.2020 18:05:40 77.699982 77.699982 0 0 0 0
06.04.2020 18:05:40 77.799988 77.799988 0 0 0 0
06.04.2020 18:05:41 78.000000 78.000000 0 0 0 0
06.04.2020 18:05:42 78.000000 78.000000 0 0 0 0
06.04.2020 18:05:42 78.100006 78.100006 0 0 0 0
06.04.2020 18:05:43 78.100006 78.100006 0 0 0 0
06.04.2020 18:05:44 78.100006 78.100006 0 0 0 0
06.04.2020 18:05:44 78.000000 78.000000 0 0 0 0
06.04.2020 18:05:45 77.899994 77.899994 0 0 0 0
06.04.2020 18:05:46 77.799988 77.799988 0 0 0 0
06.04.2020 18:05:47 77.699982 77.699982 0 0 0 0
06.04.2020 18:05:47 77.600006 77.600006 0 0 0 0
06.04.2020 18:05:48 77.399994 77.399994 0 0 0 0
06.04.2020 18:05:49 77.199982 77.199982 0 0 0 0
06.04.2020 18:05:49 77.000000 77.000000 0 0 0 0
06.04.2020 18:05:50 77.100006 77.100006 0 0 0 0
06.04.2020 18:05:51 77.299988 77.299988 0 0 0 0
06.04.2020 18:05:52 77.399994 77.399994 0 0 0 0
06.04.2020 18:05:53 77.399994 77.399994 0 0 0 0
06.04.2020 18:05:54 77.399994 77.399994 0 0 0 0
06.04.2020 18:05:54 77.299988 77.299988 0 0 0 0
06.04.2020 18:05:55 77.299988 77.299988 0 0 0 0
06.04.2020 18:05:56 77.299988 77.299988 0 0 0 0
06.04.2020 18:05:57 77.299988 77.299988 0 0 0 0
06.04.2020 18:05:58 77.199982 77.199982 0 0 0 0
06.04.2020 18:05:59 77.000000 77.000000 0 0 0 0
06.04.2020 18:05:59 76.799988 76.799988 0 0 0 0
06.04.2020 18:06:00 76.600006 76.600006 0 0 0 0
06.04.2020 18:06:01 76.399994 76.399994 0 0 0 0
06.04.2020 18:06:01 76.500000 76.500000 0 0 0 0
06.04.2020 18:06:02 76.600006 76.600006 0 0 0 0
06.04.2020 18:06:03 76.799988 76.799988 0 0 0 0
06.04.2020 18:06:04 77.000000 77.000000 0 0 0 0
06.04.2020 18:06:04 77.199982 77.199982 0 0 0 0
06.04.2020 18:06:05 77.399994 77.399994 0 0 0 0
06.04.2020 18:06:06 77.600006 77.600006 0 0 0 0
06.04.2020 18:06:06 77.699982 77.699982 0 0 0 0
06.04.2020 18:06:07 77.899994 77.899994 0 0 0 0
06.04.2020 18:06:08 78.100006 78.100006 0 0 0 0
06.04.2020 18:06:09 78.299988 78.299988 0 0 0 0
06.04.2020 18:06:09 78.399994 78.399994 0 0 0 0
06.04.2020 18:06:10 78.399994 78.399994 0 0 0 0
06.04.2020 18:06:11 78.500000 78.500000 0 0 0 0
06.04.2020 18:06:12 78.399994 78.399994 0 0 0 0
06.04.2020 18:06:13 78.299988 78.299988 0 0 0 0
06.04.2020 18:06:13 78.100006 78.100006 0 0 0 0
06.04.2020 18:06:14 78.000000 78.000000 0 0 0 0
06.04.2020 18:06:15 77.899994 77.899994 0 0 0 0
06.04.2020 18:06:16 77.699982 77.699982 0 0 0 0
06.04.2020 18:06:16 77.600006 77.600006 0 0 0 0
06.04.2020 18:06:17 77.399994 77.399994 0 0 0 0
06.04.2020 18:06:18 77.399994 77.399994 0 0 0 0
06.04.2020 18:06:18 77.299988 77.299988 0 0 0 0
06.04.2020 18:06:19 77.299988 77.299988 0 0 0 0
06.04.2020 18:06:20 77.199982 77.199982 0 0 0 0
06.04.2020 18:06:20 77.100006 77.100006 0 0 0 0
06.04.2020 18:06:21 77.000000 77.000000 0 0 0 0
06.04.2020 18:06:22 77.000000 77.000000 0 0 0 0
06.04.2020 18:06:23 76.799988 76.799988 0 0 0 0
06.04.2020 18:06:23 76.699982 76.699982 0 0 0 0
06.04.2020 18:06:24 76.500000 76.500000 0 0 0 0
06.04.2020 18:06:25 76.399994 76.399994 0 0 0 0
06.04.2020 18:06:25 76.199982 76.199982 0 0 0 0
06.04.2020 18:06:26 76.100006 76.100006 0 0 0 0
06.04.2020 18:06:27 75.899994 75.899994 0 0 0 0
06.04.2020 18:06:28 75.699982 75.699982 0 0 0 0
06.04.2020 18:06:29 75.600006 75.600006 0 0 0 0
06.04.2020 18:06:30 75.600006 75.600006 0 0 0 0
06.04.2020 18:06:31 75.799988 75.799988 0 0 0 0
06.04.2020 18:06:32 76.000000 76.000000 0 0 0 0
06.04.2020 18:06:32 76.199982 76.199982 0 0 0 0
06.04.2020 18:06:33 76.299988 76.299988 0 0 0 0
06.04.2020 18:06:34 76.299988 76.299988 0 0 0 0
06.04.2020 18:06:35 76.299988 76.299988 0 0 0 0
06.04.2020 18:06:35 76.100006 76.100006 0 0 0 0
06.04.2020 18:06:36 75.899994 75.899994 0 0 0 0
06.04.2020 18:06:37 75.600006 75.600006 0 0 0 0
06.04.2020 18:06:37 75.199982 75.199982 0 0 0 0
06.04.2020 18:06:38 75.000000 75.000000 0 0 0 0
06.04.2020 18:06:39 74.699982 74.699982 0 0 0 0
06.04.2020 18:06:39 74.600006 74.600006 0 0 0 0
06.04.2020 18:06:40 74.399994 74.399994 0 0 0 0
06.04.2020 18:06:41 74.199982 74.199982 0 0 0 0
06.04.2020 18:06:42 74.000000 74.000000 0 0 0 0
06.04.2020 18:06:42 74.100006 74.100006 0 0 0 0
06.04.2020 18:06:43 74.299988 74.299988 0 0 0 0
06.04.2020 18:06:44 74.399994 74.399994 0 0 0 0
06.04.2020 18:06:44 74.500000 74.500000 0 0 0 0
06.04.2020 18:06:45 74.600006 74.600006 0 0 0 0
06.04.2020 18:06:46 74.600006 74.600006 0 0 0 0
06.04.2020 18:06:47 74.399994 74.399994 0 0 0 0
06.04.2020 18:06:48 74.299988 74.299988 0 0 0 0
06.04.2020 18:06:48 74.199982 74.199982 0 0 0 0
06.04.2020 18:06:49 74.000000 74.000000 0 0 0 0
06.04.2020 18:06:50 73.799988 73.799988 0 0 0 0
06.04.2020 18:06:50 73.500000 73.500000 0 0 0 0
06.04.2020 18:06:51 73.100006 73.100006 0 0 0 0
06.04.2020 18:06:52 72.799988 72.799988 0 0 0 0
06.04.2020 18:06:53 72.399994 72.399994 0 0 0 0
06.04.2020 18:06:54 71.899994 71.899994 0 0 0 0
06.04.2020 18:06:54 71.299988 71.299988 0 0 0 0
06.04.2020 18:06:55 70.899994 70.899994 0 0 0 0
06.04.2020 18:06:56 70.799988 70.799988 0 0 0 0
06.04.2020 18:06:56 70.899994 70.899994 0 0 0 0
06.04.2020 18:06:57 71.399994 71.399994 0 0 0 0
06.04.2020 18:06:58 72.000000 72.000000 0 0 0 0
06.04.2020 18:06:59 72.500000 72.500000 0 0 0 0
06.04.2020 18:06:59 73.000000 73.000000 0 0 0 0
06.04.2020 18:07:00 73.299988 73.299988 0 0 0 0
06.04.2020 18:07:01 73.600006 73.600006 0 0 0 0
06.04.2020 18:07:01 73.699982 73.699982 0 0 0 0
06.04.2020 18:07:02 73.899994 73.899994 0 0 0 0
06.04.2020 18:07:03 74.000000 74.000000 0 0 0 0
06.04.2020 18:07:04 74.100006 74.100006 0 0 0 0
06.04.2020 18:07:04 74.199982 74.199982 0 0 0 0
06.04.2020 18:07:05 74.299988 74.299988 0 0 0 0
06.04.2020 18:07:06 74.299988 74.299988 0 0 0 0
06.04.2020 18:07:07 74.199982 74.199982 0 0 0 0
06.04.2020 18:07:08 74.199982 74.199982 0 0 0 0
06.04.2020 18:07:09 74.100006 74.100006 0 0 0 0
06.04.2020 18:07:09 74.000000 74.000000 0 0 0 0
06.04.2020 18:07:10 73.899994 73.899994 0 0 0 0
06.04.2020 18:07:11 73.799988 73.799988 0 0 0 0
06.04.2020 18:07:11 73.600006 73.600006 0 0 0 0
06.04.2020 18:07:12 73.500000 73.500000 0 0 0 0
06.04.2020 18:07:13 73.399994 73.399994 0 0 0 0
06.04.2020 18:07:14 73.199982 73.199982 0 0 0 0
06.04.2020 18:07:14 73.100006 73.100006 0 0 0 0
06.04.2020 18:07:15 73.000000 73.000000 0 0 0 0
06.04.2020 18:07:16 73.000000 73.000000 0 0 0 0
06.04.2020 18:07:16 73.199982 73.199982 0 0 0 0
06.04.2020 18:07:17 73.100006 73.100006 0 0 0 0
06.04.2020 18:07:18 73.100006 73.100006 0 0 0 0
06.04.2020 18:07:19 73.000000 73.000000 0 0 0 0
06.04.2020 18:07:19 72.799988 72.799988 0 0 0 0
06.04.2020 18:07:20 72.600006 72.600006 0 0 0 0
06.04.2020 18:07:21 72.299988 72.299988 0 0 0 0
06.04.2020 18:07:21 72.000000 72.000000 0 0 0 0
06.04.2020 18:07:22 71.600006 71.600006 0 0 0 0
06.04.2020 18:07:23 71.000000 71.000000 0 0 0 0
06.04.2020 18:07:23 70.500000 70.500000 0 0 0 0
06.04.2020 18:07:24 70.299988 70.299988 0 0 0 0
06.04.2020 18:07:25 70.500000 70.500000 0 0 0 0
06.04.2020 18:07:26 70.799988 70.799988 0 0 0 0
06.04.2020 18:07:26 71.299988 71.299988 0 0 0 0
06.04.2020 18:07:27 71.799988 71.799988 0 0 0 0
06.04.2020 18:07:28 72.100006 72.100006 0 0 0 0
06.04.2020 18:07:28 72.399994 72.399994 0 0 0 0
06.04.2020 18:07:29 72.699982 72.699982 0 0 0 0
06.04.2020 18:07:30 72.799988 72.799988 0 0 0 0
06.04.2020 18:07:30 73.000000 73.000000 0 0 0 0
06.04.2020 18:07:31 73.199982 73.199982 0 0 0 0
06.04.2020 18:07:32 73.399994 73.399994 0 0 0 0
06.04.2020 18:07:33 73.500000 73.500000 0 0 0 0
06.04.2020 18:07:33 73.600006 73.600006 0 0 0 0
06.04.2020 18:07:34 73.500000 73.500000 0 0 0 0
06.04.2020 18:07:35 73.399994 73.399994 0 0 0 0
06.04.2020 18:07:35 73.299988 73.299988 0 0 0 0
06.04.2020 18:07:36 73.100006 73.100006 0 0 0 0
06.04.2020 18:07:37 73.000000 73.000000 0 0 0 0
06.04.2020 18:07:37 72.699982 72.699982 0 0 0 0
06.04.2020 18:07:38 72.399994 72.399994 0 0 0 0
06.04.2020 18:07:39 72.100006 72.100006 0 0 0 0
06.04.2020 18:07:40 71.699982 71.699982 0 0 0 0
06.04.2020 18:07:40 71.399994 71.399994 0 0 0 0
06.04.2020 18:07:41 70.899994 70.899994 0 0 0 0
06.04.2020 18:07:42 70.399994 70.399994 0 0 0 0
06.04.2020 18:07:42 69.799988 69.799988 0 0 0 0
06.04.2020 18:07:43 68.799988 68.799988 0 0 0 0
06.04.2020 18:07:44 68.000000 68.000000 0 0 0 0
06.04.2020 18:07:45 67.299988 67.299988 0 0 0 0
06.04.2020 18:07:45 66.500000 66.500000 0 0 0 0
06.04.2020 18:07:46 65.699982 65.699982 0 0 0 0
06.04.2020 18:07:47 64.899994 64.899994 0 0 0 0
06.04.2020 18:07:47 64.199982 64.199982 0 0 0 0
06.04.2020 18:07:48 63.500000 63.500000 0 0 0 0
06.04.2020 18:07:49 62.899994 62.899994 0 0 0 0
06.04.2020 18:07:49 62.500000 62.500000 0 0 0 0
06.04.2020 18:07:50 62.199982 62.199982 0 0 0 0
06.04.2020 18:07:51 61.899994 61.899994 0 0 0 0
06.04.2020 18:07:51 61.600006 61.600006 0 0 0 0
06.04.2020 18:07:52 61.000000 61.000000 0 0 0 0
06.04.2020 18:07:53 60.500000 60.500000 0 0 0 0
06.04.2020 18:07:53 60.000000 60.000000 0 0 0 0
06.04.2020 18:07:54 59.699982 59.699982 0 0 0 0
06.04.2020 18:07:55 59.500000 59.500000 0 0 0 0
06.04.2020 18:07:56 59.299988 59.299988 0 0 0 0
06.04.2020 18:07:57 59.399994 59.399994 0 0 0 0
06.04.2020 18:07:58 59.399994 59.399994 0 0 0 0
06.04.2020 18:07:58 59.500000 59.500000 0 0 0 0
06.04.2020 18:07:59 59.699982 59.699982 0 0 0 0
06.04.2020 18:08:00 59.899994 59.899994 0 0 0 0
06.04.2020 18:08:00 60.100006 60.100006 0 0 0 0
06.04.2020 18:08:01 60.299988 60.299988 0 0 0 0
06.04.2020 18:08:02 60.399994 60.399994 0 0 0 0
06.04.2020 18:08:03 60.399994 60.399994 0 0 0 0
06.04.2020 18:08:03 60.199982 60.199982 0 0 0 0
06.04.2020 18:08:04 60.100006 60.100006 0 0 0 0
06.04.2020 18:08:05 60.199982 60.199982 0 0 0 0
06.04.2020 18:08:06 60.299988 60.299988 0 0 0 0
See less See more
#2 ·
When thermostat is working properly you should see at least 78C when cruising on highway and above that in the city.
#3 ·
could it be a sensor acting up as welll? Any other parameters I can set to monitor to give an idea on the situation?
Hmm. It was reading mid to upper 70s for most of that trip... it did hit 78.5C. That drive was very low impact. So steady 25-35mph with RPMs below 4K (mostly staying at 3k) and 2nd and 3rd gear mostly.
maybe I should take another 10 min drive and get on it more
#4 ·
I checked my coolant overflow tank and I was low about 20oz so I topped it off to full and went for a drive. 15 minute drove for about 10 miles and read codes when I got back and no code...so we’ll keep an eye on it. I’d think I’d get another code if coolant was slightly low but who knows.
#5 ·
You should get a warning when the coolant is below minimum level. What comes to the coolant temp it should stay in the 78C when you get there. I just used instrument cluster secret menu for diagnose my problem.
#7 ·
Im about to order the parts for the repair now from FCP Euro
OEM BMW Stat
o-rings
metal washers
gallon of BMW goop
was debating getting a new sensor....it's only ~$50 but every time I try to replace something before it NEEDS replacing I get cursed with the "break something/F something else up" fairy. So I think I'll just replace the thermostat and do the spark plugs while I'm in there...since they are due.
FYI.... the O-rings are $3 each ?
#9 · (Edited)
yep got 1 BMW thermostat, 6 o-rings (replace the 4 and 2 spare), 3 metal washers (1 spare - not sure yet what bolt this goes on), 1 gal of the OEM BMW blue goop (plan on draining/flush the entire radiator and refill)....just need to pickup 1 gallon of distilled water
Should be here today or tomorrow. $150 in parts and saving close to $1k in labor from dealer :)
Will be doing plugs this weekend too...should be a hell of a weekend haha. I'm sure I'm going to need a few ?
