1 - 12 of 12 Posts
This call goes out to Apples, Black M5, Jim Wald, Bart, TFung, and other 'Gurus of Mod'. on this board. :hihi: :hihi:
Is it physically possible to replace the automatic transmission in the SL55 by a 6-speed manual?
I think BMW buys their transmissions from Gertrag or some similar outfit, so it should be possible to buy a top-notch manual transmission unit and the shift linkage assembly.
The hurdles I can think of are mostly physical space limitations. But if one goes that far, it is conceiveable to modify the transmision housing/tunnel etc. to fit the tranny and the clutch asssembly. Don't know what it would do to the rigidity of the frame though. May have to move some seats to boot. Some warrenty items would be voided.
Would the engine management system have issues with the revs governed manually? Anything else that precludes this mod?
I know BMW Indivaiual will customize almost anything if we pay. Does MB offer similar programs? Or we'll have to try Renntech or Brabus to get the mod done?
There is also the road-feel issue, but I believe the dreaded 'dead road feel' is more associated with the S, E and C classes. Don't know if the SL class is equally 'dead'. But some fine-tuned suspension package might invigorate the road feel somewhat.
The costs for all these will not be small, but can't approach that of Nowack N500 or turbo-charging the M5. But if it can done, here's what you get:
You would loose a 100 lbs or so off the tansmission, which is always a good thing, and you can row your own gears. You'll have a car that can keep up with ANY supercar ANYWHERE (who would beat you, a GT2? not likely). A no-hassle convertable top, (no hard-top to lift, no soft-top to maintain) and a truly stunning looker of a car.
For me, THAT's the car to die for. Your comments, discussions, and education are welcomed.
CP
Renntech!
Yea, but like you said...Renntech and the $$ is crazy.
Check it out..click
that SL55 has something like 150lb ft more torque- something to consider.
from what I read about the SL55- it seems to have good road feel through the steering (rack&pinion) the real question is- does the feel get to you throough the seat? that is something that BMW has down pat.
nothing in impossible.. there are a few mercedes with conversions done to them to get a manual transmission in them.. I don't see why it cannot be done to the SL55... you will just need to find a compatible transmission that would hold up to the power of the engine... as more and more of the car's functions are turning electronic, I think it would get harder and harder to do this. Before, everything was mechanical, so it was simple to swap one thing out to replace it with another thing. Nowadays, you have to take into account of everything else in the car.. and in this case, I imagine that the ECU will have to be rewritten to some extent to accomadate a manual transmission...
Hi Terrance,
DSL up and running in the new pad already? :hihi: :hihi: :typing: :typing:
CP
A few years abck there was someone I knew of who had a Brabus or Renntech C-class with a BMW 8-series gearbox in it. I think it can be done with the SL. I do not feel that it is a mechanical issue, I am more concerned with ECU/Computer issues.
'Rocket
Straight up answer is yes but it's not easy, for one i'm not sure if
the gearbox is rated to that sort of power.
I've worked with guys from MB engineering being an engineer
myself even with my C32 there are little options for a box which
will
1. Fit
2. Handle the best Torque
So my guess is yes you can do it but like anything else you will
pay about $30K.
Heres another point the Lockup Torque converter on that box
is AMAZING ! Thats why firms like renntech will recommed against
it but if you want it it's 30K !!!
The other point is that the engine is designed for an Auto and the
torque curve acccordingly putting in a 6 speed will likely slow you
down a little. So the answer is yes but the tradeoff is HUGE !!!
chunpng said:
Hi Terrance,
CP
nope.. still no DSL.. :(
Upon further review, the SL 55 comes with a manual SMG type shifter. So you don't work the clutch or row the shifter, but at least you can stay in gear through redline before upshifting. The only way to enjoy the V8 tone really. :cheers: :cheers:
So it's not a slush box only scenerio. :D :D
CP
I believe the SL55 does not have a manual gearbox a la SMG. It is a strait-up automatic gearbox. Those button shifters are just a gimmick honestly. In those type of autoboxes, the fastest will always be leaving it in D.
I read somewhere that it will not let you hold redline.
'Rocket
Why not go for the realthing:a Brabus SL 7.3 (about 700 BHP...)
If you by one, I'm sure they will throw in a manual gearbox of your chioce for free.
Have a look at Gustav´s pictures from the 2001 trip to germany.
David
I totally agree that the SL 55 would be a far more worthy car with the manual transmission added, althought contrary to what you said, I think that the price of modifying the transmission and other necessary changes to the car to accomodate the manual transmission would FAR surpass the price of supercharging an M5.
The M5 Nowack conversation is like $13,000 (I think)? Don't quote me on that though!
The other thing I question about Mercedes is the natural balance of the car in comparison to the perfectly balanced BMW. Do you think that the Merc will be able to grasp the same feel that the bimmers do?
Many cars have the same stats on paper but don't feel the same. I think the SL 55 is going to be one of the best looking cars on the road and I know it's going to be FAST and I wouldn't mind having one even though I a die hard bimmer guy, but I'm wondering if you'll be able to get a hold on that "feel."
Just speculating. Why not wait to see what Brabus or Renntech put out...not will you be able to request a manual transmission, but the engine will be modified for more power as well.
:typing:
1 - 12 of 12 Posts
