This had me scratching my head...
Took it in for CA smog. No CELs, running fine.
Hmmm.
No CEL. Checked codes with peak, No codes
Fail. Pretty much the same numbers.
Still fails. CATs again good and hot for test.
138k miles on the ODO
Time for better computers. Took it to a shop for further tests.
So, surprised that I have a vanos issue that is causing no codes, no issues, just running a bit rich.
My plan- replacing:
Thoughts?
A
PS Anyone replace solenoid assemblies recently? What are those puppies running ($$)? I'd usually buy parts prophylactic, but these are not hard failures, and the price for two is a bit surprising....
- Failed for Hydrocarbons. 78ppm at 15mph (limit 47) and 57ppm at 25mph(limit 31) (Yes, was hot for test)
Hmmm.
- OBD scanner. Long term fuel trims elevated, 3% on bank 1, 6-7% on bank 2.
- Cleaned MAFs, changed pre AND post cat O2 sensors, new air filters, Oil change, what they heck, eh?
- Drive 300 miles, retest
- Pull the plenum, check all hoses for leaks. Replace a few. Smoke test. Nothing seen.
- MAF test gives 138.x at redline in 3rd
- Thermostat and T sensor replaced at 13k miles ago, temp readings all good.
- Autologic report, looking at O2s and adaptation shows rich... ran the VANOS test:
- Bank 2 shows "Deviation, Leak Test, Exhaust (ocr)" = 9.3 Fail (limit 7)
- Bank 1 showed 6.7, 6.8 and pass.
My plan- replacing:
- All 4 CPS,
- All solenoid o-rings (both banks).
Thoughts?
A
