1 - 6 of 6 Posts
hi been checking for error codes and the scanner threw up exhaust temp sensor fault,looked on realoem and looks likes it is an obselete part,any ideas where i could obtain this part? all connection seem good so must be the sensor thanks
If the car has been in the dealer network at any time since 2001 there is a good chance that EGT sensor is being ignored, via updated DME Software, I think.
So it is very interesting that you are seeing a code. What is the code number please ?
egt
hi m5 london the code is 4f(079). the car has been serviced by bmw so i'm sure dme has been updated any thoughts
Just because it was serviced does not mean they did the update. My car was leased from a BMW dealer, they owned it. They sold it when it was five years old, but never did one update nor did one recall, but I am sure they billed for them all. Go to a dealer with you vin and ask them to check if the software/egt delete was done.
Did you ever get any closure on this, I have recently run into the same issue where the sensor wiring has broken, throwing up a fault on the scanner. Obviously the same as you when I looked up a replacement part, I fell into the same predicament you are in, can't replace the sensor and suspect the update has not been done.
I have two questions:-
1) Should i just go to the dealer and ask them to clarify?
2) What does the sensor actually do on the old software and will it throw a light (mine is already on because of something else so i can't tell if the sensor fault would throw the light or not).
FYI car is an early facelift Nov 2000 model.
1 - 6 of 6 Posts
