1 - 10 of 10 Posts
after reading several posts about exhaust systems I think i've figured out what a 'header' and 'muffler' is. however, could someone enlighten me what the following terminologies refer to:
- section 1, 2 and 3
- x-pipe
- resonator
- cat
thanks in advance!
The e60 M5 exhaust contains 4 sections: header with primary CAT, section 1 with secondary CAT, section 2 which contains the resonator, and section 3 (muffler).
Also any modifications done to Section 1 would be straight through pipes (deleting the secondary cat) or upgrading to race cats
So most of the aftermarket systems we see, we can usually choose 1 of the 3 sections to upgrade or all of them, correct?
Company Representative of RPI Power
Correct.
You can pick and choose. Most people start with just section 3, though there are many who do 2 or all 3 sections at once. Heck, some people start at the header and go all the way back. :D
- x-pipe
- resonator
- cat
thanks in advance!
header=exhaust manifold (collects the exhaust gases and is the first part of the exhaust system)
cat=catalyst or catalytic converter (this is platinum coated cellular metalic structure which converts the exhaust gasses loaded with unburnt fuel into a more enviromentally friendly gas). Most manufacturer cell count for cats are 300 cells per inch or greater. Performance cats are around 100-200 cell count.
Hope this helps.
I made the following modifications:
1.) Evosport sec. 1 without cats.
2.) Evosport sec. 2 without resonators
3.) Tubistyle Rumore Exhaust
Now, I regret what I have done this.... :grrrrr: Now my car is too loud to be useable in the normal road.
First my problems:
1.) There is choking under low RPM 40 to 45 km/h at 2,500 RPM sometimes in 3rd or 4th gear.
2.) It is not as responsive in upshifting or downshifting
I thought you only need ECU mod when you change headers. Is ECU mod the solution to my drivability problem.
I need to lower down the volume. Can I put a custom built resonator in my Sec. 1 or is it better to be in Sec. 2?
Can I put resonators in both Sec. 1 and Sec. 2?
First my problems:
I have:
Evosport Sect 1 (catless)
Stock Section 2
Evosport Sport Muffler (quiter version)
Result: perfect sound; no drone, louder especially during WOT.
Performance improvement according to butt dyno. :haha:
1 - 10 of 10 Posts
