Many board members who are a large distance away from us have been recieving ECU Remaps/Flashes from us in the last year.
This has been mainly for the AlphaN, Power mapping and diagnostic functions.
What most have seen is the evolve cable which is the same as we use at HQ. It passes from customer to customer.
Now, we have a new solution.
The evolve-R.
This remote cable is one that you (the end user) keeps and can flash in files using your laptop with the very simple software pictures below:
This is again the exact same cable as what we use at HQ but it is locked to your ECU and costs much less to purchase (£150 maximum).
Those of you who have used our cable already know that the software is not particularly easy to setup and usually requires myself (Salman) to login remotely to your PC and carry out the whole operation.
This new version is much easier to install and the whole read/write process is far smoother and easier.
This is how it works:
- We send you the cable with software
- Install the programme on your laptop (Windows XP/Vista/7)
- Plug the cable into your USB port and then to your OBDII port
- Click the 'identify ECU' button
- Read the file by clicking on 'read ECU memory'
- Email us the file
- Await for the modified file to be sent back
- Click 'programme ECU memory' button and select the new file
The read/write time is less than 3 minutes so no worries about battery charge going down.
You can then select the origional or the tuned software.
We will supply a valet map for free which will limit the RPM's to say around 3000rpm.
If for example, you currently have a stock car and ask for the stage 1 software and then later decide to add headers and require a stage 2 remap then you use the same cable and you just purchase the relevant version from us and flash it in into the ECU.
Now, there is one problem with the MSS52 ECU. After approximately 50 flashes the ECU will lock out and you can no longer programme the ECU. We are working on a special add on feature which will allow us to reset the ECU counter back so you can continue flashing. This process will take slightly longer but won't be done that often because it will take some time for you to use up all 50 slots.
In the near future we will also supply an upgraded software which will allow the software/cable to read/clear fault codes and also carry out datalogging or read live data.
We are also looking into possibilities to upgrade the complete DME software (same as a BMW update) to the latest version or any version at that matter!
This is very much the latest in OBDII flashing / data technology at a very very cheap price.
It not only works on the MSS52 but also the MSS54 (E46 M3), MSS6x (E60 M5 and E92 M3) + many many more.
This will be available not just through us but also our dealer network.
If you have any questions please do not hesitate to ask.
The evolve-R.
- Email us the file
