1 - 16 of 16 Posts
ESS now offers a DIY option for S85 tuning.
Introducing the new Direct Flash OBD software tuning interface. ESS Direct Flash gives the end user a simple to use device that allows for self programming of our performance software. No longer will ECU removal and shipping be required to install or update the software in your vehicle.
Features Include:
100 % DIY operation with easy to follow instructions.
Easily store and switch between up to 10 tunes.
Instant access to stock and tuned files.
Updates and support via internet / email.
Software support for all US and Euro spec vehicles.
MSRP $1,295 + shipping
M5board introduction pricing $1,150 + free shipping
To order visit www.esstuning.com and use coupon code "Directflash" to apply the savings.
S85 dyno tested "stock"
Software Features :
-8400RPM limit, higher available as custom order
-Removed top speed governor
-Reprogrammed torque management
-Reprogrammed throttle response
-Reprogrammed ignition, vanos and fuel parameters for optimum operation
The software is compatible with performance cat-back exhaust systems. Header software available upon request.
Typical performance increase is 10-15WHP and 10-15ft/lbs of torque on 91AKI with software alone. 93AKI version will under normal conditions develop 15-20WHP and 15-20ft/lbs of torque.
Premium Member
Can BMW tell that you had an aftermarket ECU upgrade (ESS) if you flash the ECU back to BMW OEM before bringing it into a dealer for service?
How much does it costs to have the RPI Stage 2 tune installed?
Discussion Starter · #7 ·
No
I have your old tune that I paid 1080 for is there a step up tune price since I already paid 1080 for the old tune I just dont want to bust out another grand ?
Direct flash software is different than our standard software in terms of coding. To change over it would require a complete reflash of your currect software and cost would be the same.
Contact Eloy at RPI to check on this.
I read here on another post here that the dealership scanned a "tuned" car and while it did not detect a "tune" per se, it did collect data that the car exceeded 8,250 RPM and thus voided the warranty. I believe the car needed engine repair.
Any comments regarding that? That is what worries me about flashing the ECU.
Discussion Starter · #9 ·
If RPM limit is a concern you can always request stock RPM limit with our software.
[email protected] I think this ESS Tuning Direct Flash software a great offer but I have a question for you, according to the E60 M5 Complete vehicle Aftersales Training (see link bellow) the DME for the S85B50 (control unit Siemens MS_S65) can only be reprogrammed up to 63 times. Do you confirm that ?
https://files.me.com/clyde1138/940735
ESS tune ... DME reprogrammability
Has anyone been able to confirm this? Ie only able to reprogram 63 times? Tx
The 63 times limit applies to the reprogramming the whole DME. The tune only flshes a particular section of the ECU and does not count towards the DME reprogramming count. You can flash the ECU as many times as you like.
1 - 16 of 16 Posts
