1 - 1 of 1 Posts
I have an older DICE unit hooked into my 02 with M-Audio. I now hear alot of engine whine when my ipod is connected. Engine whine is usually because of a bad ground but all the cables are plugged in tight. I suspect the unit is starting to fail because of its age (i bought it used).
After all this time, is there a better unit that I can just plug in place of this unit? Is it worth getting a newer version of DICE or is there a better alternative - or does someone have a suggestion to get rid of the noise?
I dont want to cut up the dash or have to mess around with too many wires. The dice unit plugs in nice and simple in the tunnel and would like a "plug N play" replacement if possible.
Thanks in advance for all assitance.
1 - 1 of 1 Posts
