Hi Guys,
I've tried searching this issue but haven't really found anything too concrete... I seem to have an engine vibration that kicks in at a few different points along the RPM range, first at around 1,500 RPM and then comes and goes at various points up the rev scale..
For quite some time I thought I had a wheel balance or tailshaft vibration or something, because when I drive I can feel a slight shake at certain speeds. After having wheel aligments and new diff bushes etc, I finally sat in the car stationary and slowly brought the revs up and discovered a noticeable engine vibration, which I now realise is the cause of the phantom shake while driving! :dunno:
Any ideas what this could be? This has been present since I bought the car which drives and sounds fine other than that, and occurs irrespective of clutch position (I've never had the clutch off it). It's not a misfire and I have no relevant codes (only the dreaded thermostat!). It feels like some sort of balance issue. I'm hoping this is nothing internal! Any help would be greatly appreciated.
