1 - 9 of 9 Posts
Hi Chaps
I need your advise on my engine temperature running over 100c very often. Recently its doing more so. However I must stress that I am not tracking the car, the ambient temp is not hot at all and the car is not being driven hard. I am getting this issue the minute I am in 4-5K rpm band and it goes up to 110. I understand in hotter climate zones its a slight different scenario.
I have searched the forum but the most obvious reasons that I am finding it conducive to high temp is :
1) oil coolant/radiator problem
2) low engine oil
3) incorrect vanos pressure
I do have Evolve tune on it, my primary cats are deleted as well. I am not sure if the previous owner had installed a pulley, I cant tell. during first 2 years of ownership never had this issue.
Last year the ECU did throw thermostat control unit code which was replaced under the warranty.
I also feel the power is not right and fuel consumption very heavy.
Thanks for your expertise troy.
Will take your word.
I am on 0-40 and haven't noticed a drop in operating temps since making the switch. Why would that make a difference, given ambient temps are the same for IM6 and I.
I do have to say though, my car seems to be running better overall since I did change oil. Cold starts are much much better, not as much vibration etc.
Reactions: IM6
T
Guest
Some of the benefits of moving from 10-60 to 0-40:
-the oil as a base starts off thinner than the 10-60, so it is easier during cold starts for the engine.
-engine heats up faster and gets to normal operating temps because the oil is thinner
-obviously better lubrication than a thicker oil because it is thinner and can work better with the tighter clearances of the bearings
-should be quieter vanos gears (at least that is what I have experienced).
-the thinner oil is less likely to begin to overheat because it moves through the oil cooler with less pressure. (This is the reason I think it will help the OP with his car).
**For racing driving, I recommend the 10-60
-if you are having a severe track day with 50+ miles of racing, I think 10-60 is more appropriate. At those extreme driving scenarios, the oil will eventually get too hot and that 0-40 base will thin out too much.
I am not an oil scientist, but I have a lot of personal experience with these cars since I own six of them and they all have different year and different mileage motors. I seem to be on a good oil regimen and it seems to work better than the past oil specs.
Best,
TJ
Sent from AutoGuide.com App
Great, you have confirmed all I suspected!! Thanks for confirming your specific answer to the OPs question, I didn't realise the thinner oil moved with less pressure.
As I said, I have quieter VANOS and better, easier cold starts since changing.
I love this forum!
Thanks for the info ive seen my oil temp goes a little past 210 when driving hard using LM 10W60 . Temp outside was about 65-75 degrees and didnt know if i should keep pushing it so i decided to coast and let it go back to the norm which is just under 210 for me.
I'm using Liqui Molly 10W 60 now.
As my beast uses oil, (about 1 litre/1,000 miles)
is it a good idea to try topping off with their 0-40.
Or am I better off waiting until the next full oil change?
1 - 9 of 9 Posts
