1 - 11 of 11 Posts
Hi
I'll try to understand the engine numbers. I have only a few so far
2101-001-XXXX CC8S
#021 - 2103-001-025K 806 hp (chassis +4) CCR
#07? - 2103-004-078K 662? kW CCXR (Edition/SE?)
#084 or #085 - 2104-001-089K (chassis +4 or 5) Agera
#098 - 2104-001-104K 1040 hp (chassis +6) Agera S
Can anyone contribute with some other engine numbers?
Discussion Starter #2 (Edited)
Any one have some engine numbers?
I have after last post found out that #090 have engine no 95
This is where you need to look, lower rear drivers side corner.
EDIT: Seems the engine number might have been placed somewhere else on earlier engines? Anyone know if that's the fact and where they where placed?
Engine numbers are hard to find at pictures, but engine 95 is on #090. We need more engine numbers!
Edit: noticed that I had already posted that information :^)
#021 engine 25(+4)
#084 or #085 engine 089
#090 engine 95(+5)
#098 engine 104(+6)
No one got pictures showing engine number on another car?
Sorry J_C probably no one is half as dedicated as you over here! :^)
Also is there any simpler place to find the engine number apart from on the engine? Ill try and get the Geneva cars for us this year :)
#08? - 2104-001-089K
#090 - 2104-???-095K
#093 - 2104-???-098K (old engine)
#119 - 2104-003-124K
Noticing something?
I wonder if those extra engines were used for testing etc? Or if some early engines might have been destroyed in the fire in 2003 but unlikely perhaps since they did manage to get out a few (More than two) Motori Moderni 12's..
Wild guess on the engine number sequence, but could the fourth number indicate which type of forced induction the engine has?
Was re-watching the Shmee factory tour since things have gone quiet now that winter is here but noticed this. This I believe is the second (maybe third if crash car had a new engine?) Regera engine built and most likely is currently in #126. As expected Koenigsegg is still receiving blocks from Grainger and Worrall (that's there logo on the bottom left of the script).
Manufacturing date: 28 August 2015
002 - MRB - 1: 002 = engine #2 ----- MRB - 1 = ???
14453 = ??
1 - 11 of 11 Posts
