1 - 4 of 4 Posts
elecrical problem with bi-turbo
when you turn on the headlights from the switch the lights on the dash board start to flicker and some times when it is not flickering and you use the indicator it is like some body just switched off the lights, but this is only inside the car while all this is going on outside lights are fine, any ideas i dont think its the dim switch as ive already looked at that.
Re: elecrical problem with bi-turbo
Sounds like a dirty earth connection - could be the switch needs a spray with something. These are damp days and it plays havoc with electrics....
its been doing it for a while dave even before it was off road having engine done but wasnt as bad now it does bit nearly all the time i have already had the switch out and cleaned it up with electrical contact cleaner.
Administrator
Sounds like the ground lead of the dashboard itself is loose or corroded.
1 - 4 of 4 Posts
