1 - 9 of 9 Posts
I was wondering instead of buying aftermarket oil cooler, can't i just install electric fan on the stock oil cooler, so when it the temp of the oil reached up, turn on the fan to cool it down.
It will get hotter once I install the pulley and where I live it can hit 40c in the summer.
I don't want to spend $1200 for oil cooler, this way I was thinking of electric fan, like 2 small ones, mounted on the oil cooler, once the temp goes little up, turn on the fans. I have seen it done in other cars like Evos, but their oil cooler are big, compare to others, and also they mount big fan in it. I want to know, is it worth doing it and will it cool the oil compare to bigger oil cooler.
Honestly given the small size of cooler and the like wise small fans, I cannot see it making a difference in the temp. You might see an slight improvement when at a standstill idling, but once the car is moving the fans would be meaningless. Just my thoughts.
Sure, try it!
I ran oil cooler fans on my road racing and drag racing cars back in the day and it helped. :M5rev:
1 - 9 of 9 Posts
