1 - 7 of 7 Posts
Can someone tell me why it would be better to spend the extra money on a set of Dinan sways, when Eibach's kit is 1mm thicker (front and back) and about $200 less.
I am a big supporter for Dinan products and the research that goes into them, but in this case is Eibach clearly a better choice?
Super Moderator
realistically, you don't need a new front bar. Assuming your goal is to reduce understeer, you want a stiffer rear bar. Adding both front and rear may make the car corner flatter, but may also reduce overall grip, and depending on the % change in roll stiffness, may not make any significant improvement in ballance.
Short answer, just do the rear bar, front offers little, for a lot of labor.
1 - 7 of 7 Posts
