1 - 6 of 6 Posts
Hi
I have installed egt sensor - but I thing my egt numbers are too high I saw 790 degrees celzium ( 1460 f ) on wot yesterday - if normaly cruising at stable speed I see 700-740 degrees ... can some one tell me is that normal for M5
BTW yesterday I but denso iridium IXU22 on the S38B38 can it be the problem ?
1460 is is perfectly normal for an aspirated car, where did you puy the probe ???
In turbo cars we usualy use it 10 cm after the turbo, and see a little bit colder than that, like 1350. If it is stick before the turbo, just after the ex. manifold 1450 is pretty ok
1 - 6 of 6 Posts
