EDC Re-build DIY
Firstly, EDC rear dampers are a simple dare I say “primitive” design.
Nothing fancy about them at all.
The main cost of these units comes from the “Body” design.
This makes the non-availability of a repair kit even more annoying.
Facts I found during my “Re-build”:
With 209.000 Km use on my unit, the main Rod is in good condition.
No groves, no scares.
There are only 4 replaceable items.
1.The top Rod-seal (that’s the one that leaks)
2-3. The O-ring with the Nylon coil (Looks like a bog-standard Item to me)
4.The inner tube Ring
Once the spring is removed, replacing these 4 items should not take longer then 30 min incl. cleaning everything (I used alcohol, and then re-assembled all with a little CHM fluid.)
Special tools required: None, a vice and a Plumbers Pipe wrench was all I had to remove the top collar.
Special settings or adjustment:
To be honest, I could not think of any adjustment on the rears.
The two solenoids Valves have only 3 wires going to them.
I believe these are 12v X2, plus one Ground.
If you give 12V to the solenoids they open, cut the power and they close.
Oil viscosity, amount of Oil is set by design so nothing we could change there.
(Unlike Motorcycle forks, where you can set the damping with the oil thickness, thicker Oil = stiffer damping.)
I had a damaged rear-EDC damper with 4000 miles use in the shed one solenoid was broken due to Trolly jack slipping by the pervious owner( don’t you just love Ebay?)
Just changed the entire Rod assembly into my old body, no leaks all seams fine.
Perhaps the people that do the Re-Build could offer a seal-Set.
That could help our M5 Drivers in the US, Australia???
The fitting is NOT a big issue in my eyes.
Best regards
Raz
(Sorry for the Photo, only done with my Mobile)
Best regards
Raz
