1 - 20 of 22 Posts
How do reach in to the other side of the wheel ?? And does the Windex get the brake dust and the road grime from the inner part of the wheel ??
Be careful what you wash your wheels with. I'm sure you probably
researched it before you tried it. Windex isn't acidic with a ph level
of 10.7 however an unfortunate forum member's experience with
an acidic based cleaner (stupid dealership):
http://www.m5board.com/vbulletin/showthread.php?t=102423&highlight=neez+paint
When I wash my car I always put a coat of wax on them. Makes them
easy to clean next time around.
Premium Member
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU like Mac OS X; en) AppleWebKit/420.1 (KHTML, like Gecko) Version/3.0 Mobile/4A102 Safari/419.3)
carlsturm said:
I'll have to try that wax trick !!!
its called wheel wax. don't use car wax..
Wheel cleaning.
I have a special brush, shaped like a christmas tree, about a foot long and slightly flexible. Think it was branded Megiuars, but packaging re-cycled months ago.
With the standard M5 wheels it is quite easy to clean the outside and inner rims with this brush. It is necessary to move the car to reach the part behind the brake caliper, but no big problem.
I have found the wheels are easier to clean since I used a spray-on slippery silicone emulsion tire dressing product and some of it spilled over onto the rims. They now repel water and dirt very well.
I assume Windex is a domestic window glass cleaner, if it has a pH of over 10 it is quite alkaline. I guess it contains ammonia.
Wonder Wheels on the other hand is partly dilute Hydrochloric acid.
Aluminum is corroded by both acid and alkali, but alkalis can actually dissolve the alloy.
Best to be sure your wheel coatings are intact before you use either.
To make a tedious job a little easier, I sit on one of those wheeled seats that are sold for gardeners. Talking of tedious, I find cleaning the tail pipes is much worse than doing the wheels.
When I wash my car I always put a coat of wax on them. Makes them easy to clean next time around.
When did that happen??? :rofl::rofl::rofl:
Whew......... That was a good one. I'm gonna take a shower now, worked up a sweat and I think pulled a ligament!:hihi:
jk....JK!!:blink: Your always working!:dunno:
Discussion Starter · #10 ·
:D - true confessions, I didn't clean the 'other side' of the wheel. Now you've shamed me into pulling out the bucket, wheel cleaner and attachments.
oops sorry, but really the wheel looks lousy when the inside of it looks like sh_t.....
Windex is a mild product, but is not a dedicated wheel cleaner. It could cause damage that will only show up with long term use ouich
My favorite wheel cleaner is P21S. I used it for 10 years on my daily driver M3 :M5thumbs:
http://carcareonline.com/detail.asp?product_id=10401
Cleaning the backside (of a wheel)
It is no problem to push the brush through at an angle and remove all visible dirt from the inside rim.
See pic. and no the wheels have not been cleaned in the last 500 miles, but you can see they are fairly clean from the last session.
That's the exact same brush I use, bought from your local Halfords by any chance? Near perfect for our wheels, I bought the proper wheel brush set from BMW but really not worth it, brissles too short and abrasive in my opinion.
M500AED just keep an eye on the rubber "nipple" on the end of the brush, when it starts to wear out replace the brush or you might end up scratching the inside of the alloy with the wire core.
that's the same brush I use too! it's from Megiuars! it's pretty good and long enough to clean "the other side" of the wheel!!
but! just becareful with the steel wires in the middle, I find that if you press the brush too hard on the corners when you wash, the steelwires might come in touch with the wheel.. (press really hard.....)
Otherwise, that brush is really good, easy to clean outside and inside!
coat the wheels with REJEX! It's the best for "wax" on the wheels or any other part of the car.
If it's good enough for aircraft, it's good enough for me :M5thumbs:
Skygeek sells a 16oz bottle for less money than a local auto supply sells an 8oz bottle :biggrinbounce:
http://www.skygeek.com/61002.html
If you really want to save, buy the gallon :hihi:
http://www.skygeek.com/61004.html
RejeX is excellent on wheels and exhaust pipes and glass and paint ....
Some fancy products like Zaino or Zymol can give a better shine, but the shine and protection does not last. The heavy rains (for California) this winter showed the durability of RejeX :applause:
1 - 20 of 22 Posts
