61 - 80 of 113 Posts
7E6DB010-D49F-4BFC-94EB-D2098CA6380C.jpeg Was a bit of a pain. I took the entire side off with the buttons so I could do it under better lighting. If you look at the red button you can see it clips into those two holes on the side of the button so that’s where I pushed the black button from the back side. The whole thing shot out but the button came out of the frame when both shot out. I thought I broke it but its all made to come out. Then you push the frame back in and put the red button in from the top and it all clicks back together.
One thing is if you take the panel off be careful there are two little white T shaped inserts that flew out and I had no idea what it was from at first. They go in the holes of the up/down arrows on the back side of the button to make the button work. So make sure you don’t lose those.
68 with tax and shipping for me. Overall not a terrible price. I wish there was a blue one to match the blue start button
think I got my start button for $20 on ebay. And got the M button for $20 on ebay before he raised the price. $40 shipped for both :devil
Removed the trim and drilled out the old one to make it easier:
Had a quick look at the Start/Stop button but couldn't see how to remove it. Popped the housing that it sits in (with the headlight switch, its RHD) but couldn't see how to get it off without removing the entire button assembly. Quickly put it all back together lest I break something. What did I miss?
you have to pull out the entire assembly. then you'll see that the start/stop button assembly can be removed. once you remove it you simply pry off the black start/stop cap, snap the red one in place the put everything back together in reverse order.
Many thanks. I thought that may have been the case but didnt want to start pulling it apart until I was certain.
I ended up using a trim removal tool and a small pick for the button. I only removed the outer ring and carefully picked the button off without breaking any of the little plastic tabs on the button. Took me like 5min to install.
Tools I used to remove outer ring and button.
Button removed
Button installed
Waiting to purchase a new steering wheel to install my red M button :grin
Thanks mate. Of course my setup differs to yours.
On RHD cars the start/stop is mounted in the headlight switch area. So, I removed the panel containing the switch and start/stop. Then removed the button assembly, popped the black button off. Replaced it with the glorious red and reinstalled. Took 5 minutes once I had a T6 torx in hand. The steering wheel was as simple, but man when those little white rocker button things come flying out they are hard to find. Especially when they drop into a seat rail. Thank goodness for garden blower vacs.
Care to share some pictures? I'm curious now to see how it's mounted on RHD vehicles :grin
Fail!! I wish I looked at the red button a bit more careful before removing everything. Wrong size :( I think this was meant for a E90 M3. I reached out to Autotecknic about receiving the wrong size.
That sucks!
