Well, it's been a few months since the last bit of weirdness from the M5, so it's obviously now time for some new weirdness. Thoughts, ideas, suggestions appreciated.
First noticed it a couple weeks ago, and it remains an elusive thing to try to capture on video. But basically, when coming to a stop after a bit of driving (minimum 20-25 minutes), there is a sort of metallic rattling or fluttering coming from the front right side of the engine -- or at least I hear it mostly through the passenger window. It's got a slightly pulsing quality to it, definitely not a constant rattle. Sometimes it sounds almost like some sort of cavitating, but that's a loaded word to use, or as if it something were loose and spinning or moving freely for a short bit.
It seems to only occur when coming to a stop and goes away when I step on the gas. It also goes away fairly quickly (a few seconds) if I just let the car idle. It ... seems ... to start when the SMG kicks down into neutral as I coast into a stop. It does not happen when the engine and the transmission are cold, and it doesn't happen (or I don't hear it) when the car's moving or under load.
There are no codes.
Here are a couple attempts at trying to capture the noise on video. It's hard to hear; headphones help a bit.
In this one you hear it clearest at around the 12-second mark:
And in this one it also starts around the 12-second mark, though a car passes me just right then, so that overwhelms things briefly:
There are no codes.
