1 - 5 of 5 Posts
Hi all,
I keep getting a CEL only when I floor the car and it reaches a high rpm.
Ive taken it to multiple garages and they all said its either the fuel pump or post cat oxygen sensor. Ive changed the fuel pump as well as the post cat and pre cat oxygen sensors but that hasnt solved the problem
Any ideas what it could be? Ive attached the fault codes
I know you said you changed the pump but have you checked plug are all connected good done a fuel pump test to make sure everything is OK? I would try that
Sent from my SM-N9005 using Tapatalk
Injectors...clean or replace.
It happned to me.
1 - 5 of 5 Posts
