Hello
I'm an active member at M3Forum.net, same screen name. I hope you all don't mind a fellow Bimmer freak popping in for a little advice/input, so here goes.
I'm on my 4th M3, so I'm familiar with running costs, fixing these cars, etc. While my current E46M is just a gem of a car, it's harsh ride quality and high strung motor can get tiring at times. Ironically, these two traits are what give the 46M its appeal, but my gut tells me that the E39 M5 is the better "street" car. In addition, I've always had a massive crush on the 39M. With that said, I've done some reading and I've picked up on what seem to be the common issues with these cars but wanted some feedback from all of you in two areas: my assessment of the 39M's issues and how the car compares to the 46M.
39M Issues:
The issues list seems rather short, so let's see how far off I am. I'll list them in no particular order:
1. Rod Bearings: This is something I would not be afraid to fix myself... however, how common is this? Is it only the older cars? High mileage cars? Is the only symptom a light knock at idle?
2. Carbon Buildup in heads: not an issue in my mind as the software "fix" is effective and the issue doesn't affect performance. Am I missing anything here?
3. Clutch: Like any clutch, depends on usage... however, is there a general correlation between mileage and a toasted clutch? Is a car with 90k miles for sure going to need a clutch soon if not done previously?
4. Rear Sway Bar: what's the real deal with this? Random? Only happens on cars with modified suspension? Is this really an "issue"?
5. Vanos: seems sorta hit or miss, similar to the 46M, with most failures happening early in the car's life. Am I on the right track here?
6. Anything else I missed?
39M vs. 46M:
To any of you who've either owned a 46M or have spent considerable time behind the wheel, give me your brutally honest opinion on making this move... am I crazy? Should I have done it sooner?
Thanks for your time,
Eric
39M Issues:
39M vs. 46M:
Eric
