1 - 5 of 5 Posts
BOM:
·<FONT size=3> 1 – 51.71.2.694.217 Left (bank2) Firewall Cover<B><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
http://www.ecstuning.com/BMW-E39-M5s62_5.0L/Search/SiteSearch/51712694217/ES128289/<o:p></o:p>
· 1 - 51.71.2.694.218 Right (bank1) Firewall Cover<o:p></o:p>
o 03 CENTRE ENGINE COMPARTMENT CLOSING PANEL RECHTS 1 51712694218 $37.17<o:p></o:p>
o http://www.ecstuning.com/BMW-E39-M5-S62_5.0L/Search/SiteSearch/51712694218/ES128290/<o:p></o:p>
· 5 – 51.71.8.204.904 Lock<o:p></o:p>
o 02 Lock 4 51718204904 $0.65 (There are 5 not 4. Three for the left cover and two for the right).<o:p></o:p>
o http://www.ecstuning.com/BMW-E39-M5-S62_5.0L/Search/SiteSearch/51718204904/ES129774/<o:p></o:p>
· 3 – 61.13.1.925.120 Clamp<o:p></o:p>
o 11 Clamp 3 61131925120 $0.32<o:p></o:p>
o http://www.ecstuning.com/Search/SiteSearch/61131925120/ES264768/
<o:p></o:p>
http://realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=51_2292&hg=51&fg=80&hl=11
<o:p></o:p>
· Total Parts Cost - $78.55 List (realOEM.com 11/30/2013)<o:p></o:p>
· Total Time <1hr.
<o:p></o:p>
Removal:<o:p></o:p>
1. Remove the right side (bank1) and left side (bank2) Cabin Filter covers<o:p></o:p>
a. RIGHT MICROFILTER SERVICE COVER 1 04/1998 64318379626 $27.50<o:p></o:p>
b. LEFT MICROFILTER SERVICE COVER 1 04/1998 64318379627 $27.50
<o:p> Vehicle Auto part Car Engine Hood
Vehicle Car Auto part Hood Engine
</o:p>
2. Remove the right, left side and center cabin filter and windshield weather seals<o:p></o:p>
a. 28 Sealing windshield panel 1 03/1998 51718238595 $10.84<o:p></o:p>
b. 29 seal, microfine filter housing left 1 03/1998 51718238599 $21.68<o:p></o:p>
c. 30 seal, microfine filter housing right 1 03/1998 51718238600 $21.68<o:p></o:p>
3. Remove the right and left cabin filter boxes (left side remember to disconnect the Hood Switch).<o:p></o:p>
a. 03 HOUSING LOWER PART MICROFILTER RIGHT 1 04/1998 64318379624 $83.68 <o:p></o:p>
b. 03 HOUSING LOWER PART LEFT MICROFILTER 1 04/1998 64318379625 $83.68
4. Remove the right and left Air Channels<o:p></o:p>
a. 07 RIGHT MICROFILTER AIR CHANNEL 1 04/1998 64318379620 $66.08<o:p></o:p>
b. 07 LEFT MICROFILTER AIR CHANNEL 1 04/1998 64318379621 $66.08
<o:p> Auto part Hood Motor vehicle Vehicle Car
</o:p>
<o:p> Tire Vehicle Auto part Car Automotive exterior
</o:p>
5. Right side cover must be removed first, turn both of the locks ½ turn (either direction) so that the lock’s tab is parallel to the ground (horizontal). This will release the lock.<o:p></o:p>
a. Remove the locks by bulling straight forward (towards front of vehicle).<o:p></o:p>
b. Using a small flat screwdriver remove the clamp between the windshield cowl and the right side firewall cover<o:p></o:p>
c. Remove the right side cover
</o:p>
</o:p>
6. Left side cover turn the three locks ½ turn (either direction) so that the lock’s tab is parallel to the ground (horizontal). This will release the lock. 1 lock is directly behind the engine harness. You will need to remove the harness from the cover and push it out of the way to gain access to the third lock<o:p></o:p>
b. Using a small flat screwdriver remove the two clamps between the windshield cowl and the left side firewall cover<o:p></o:p>
c. Remove the left side cover
<o:p> Bumper Automotive exterior Auto part Trunk
</o:p>
</o:p>
Installation:<o:p></o:p>
1. Install the Left cover<o:p></o:p>
a. Insert the lock in the three holes and fasten by turning the locks ½ turn so that the tabs are perpendicular (vertical) to the ground.<o:p></o:p>
b. With the cover and the three locks in place re-install the two clamps between the left cover and the windshield cowl.
c. Replace the Engine Harness into the cavity in the Left side Firewall Cover.
<o:p> Tire Automotive tire Auto part Automotive wheel system Rim
</o:p>
</o:p>
<o:p> Tire Automotive tire Motor vehicle Automotive exterior Auto part
</o:p>
2. Install the Right cover<o:p></o:p>
a. Insert the lock in the two holes and fasten by turning the locks ½ turn so that the tabs are perpendicular (vertical) to the ground.<o:p></o:p>
b. With the cover and the two locks in place re-install the clamp between the right cover and the windshield cowl.
<o:p>
</o:p>
<o:p> Auto part Engine Vehicle Automotive exterior Car
</o:p>
<o:p> Vehicle Car Auto part Luxury vehicle Hood
</o:p>
3. Check that the harness is properly positioned and that all 5 locks are secure.<o:p></o:p>
4. Install the right and left Air Channels.<o:p></o:p>
5. Install the right and left Cabin Filter boxes.<o:p></o:p>
a. Reconnect the Hood Switch.<o:p></o:p>
6. Install the Windshield weather seal.
Vehicle Car Auto part Family car
7. Install the right and left Cabin Filer weather seals.<o:p></o:p>
8. Install the left and right Cabin Filter Covers. <o:p></o:p>
9. Remove shop light and any tools.
<o:p> Land vehicle Vehicle Car Engine Auto part
</o:p>
10. Close the Hood.<o:p></o:p>
11. Find a Beer. :beerglass:<o:p></o:p>
· Links<o:p></o:p>
Cabin Filter<o:p></o:p>
http://realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=64_0673&hg=64&fg=10<o:p></o:p>
http://www.ecstuning.com/Search/SiteSearch/64318379626/ES179026/<o:p></o:p>
http://www.ecstuning.com/Search/SiteSearch/64318379627/ES179027/<o:p></o:p>
http://www.ecstuning.com/Search/SiteSearch/64318379624/ES179024/<o:p></o:p>
http://www.ecstuning.com/Search/SiteSearch/64318379625/ES179025/<o:p></o:p>
http://www.ecstuning.com/Search/SiteSearch/64318379620/ES179022/<o:p></o:p>
http://www.ecstuning.com/Search/SiteSearch/64318379621/ES179023/<o:p></o:p>
<o:p></o:p>
Seals<o:p></o:p>
http://realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=41_0057&hg=41&fg=35<o:p></o:p>
http://www.ecstuning.com/Search/SiteSearch/51718238595/ES129986/<o:p></o:p>
http://www.ecstuning.com/Search/SiteSearch/51718238599/ES129987/<o:p></o:p>
http://www.ecstuning.com/Search/SiteSearch/51718238600/ES129988/<o:p></o:p>
<o:p></o:p>
Firewall Covers <o:p></o:p>
http://realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=51_2292&hg=51&fg=80&hl=11<o:p></o:p>
http://realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=51_2258&hg=51&fg=20<o:p></o:p>
http://www.ecstuning.com/Search/SiteSearch/61131925120/ES264768/<o:p></o:p>
A just-in-time delivery of a solution to a new head-scratcher. I'm giving my girl her fourth life, replacing all the shiny parts, feeding her her biannual pair of MAF Tasty Treats, and a dozen other high-priority things, but the cracking rubber insulation pieces, gaskets, and seals all around have been driving me nuts. I've been saving the firewall-cabin box area for last because it always annoys me - unfortunately I don't have either the arms of an eight year old girl or, usually, the patience to let the engine cool. Thanks for making it easy(-ier), particularly the part links - I love not having to spend an hour finding, confirming, and reconfirming part numbers and then feeling like I threw the dice anyway. :)
Great write up! Have been thinking about dong this one myself too. I'm pretty sure the ones on mine will turn to dust soon as they did on my 540i when got over ~11 years old and being in Texas heat.
1 - 5 of 5 Posts
