1 - 14 of 14 Posts
To all, many thanks for passing the wisdom of experience on to the rest of the M5 owners' world, I greatly appreciate it!
My nav screen on my 2000 e39 M5 recently froze then, after a minute or so, went blank, although with thin lines left dancing horizontally at the bottom of the screen (which are still there every time I turn the ignition key on). All the electronics associated with the screen still work (radio, CD player, etc), just no good display.
I've checked the M5 Nav threads and tried a quick fix (let the light go out, disconnect the battery, wait 15 min, reconnect the battery) to no avail. I went to a recommended website for a software fix, but the website no longer exists (at least that is what my browser told me).
So I'm to the point of changing out the Nav CD player/computer/software. I have a Mark II and am thinking I should go ahead and upgrade to a Mark IV (anybody got one they'd like to sell?). As I understand it, it is a simple plug and play.
Before I drop a hundred or so $$$ on a used one, has anyone had any issues with this upgrade?
Many thanks in advance
Mojo
It is a simple plug and play. I am selling my MKIV Unit with 2014 disk if you want. PM me for details
Good luck with your search.
An upgrade from a MKII to MK IV isn't cheap.
Recently I purchased a compete MK IV kit from bimmernav including head unit, bluetooth & sirius modules and AUX input, which is big money. But with that I get everything and the latest versions of the hardware.
They have some good DIY videos too.
Is the headunit/screen plug and play also?
Sorry for the easy question, just starting my research now on stuff. I have a 2000 and wanna upgrade to the wide screen. Also mkiv is that still out of an e39?
Edit: found some good sources and got my answers!
The screen is plug and play, but to go from a Mk II to a MK IV computer you need an adapter cable that Bimmernav.com sells.
Mojo
I was unaware of the requirement of an adapter cable. Do you have a part number or link to the cable that bimmernav is selling?
You do need to disconnect the GPS antenna from the Trimble Unit, which is integral to the MK-III and Mk-IV navigation computers, and connect the antenna to the new computer.
The 4.3 display will work with the Mk-III and Mk-IV computers, but the split screen function will be somewhat useless, if it functions at all.
That adapter is for the Old Generation to New Generation radios. It is not required for the navigation computer.
Right. I have a case of the dumbs.
I have a MKIV unit and wide scree with Diny Knobs for sale. Comes with 2014 disk too.
Who fixes the MK 4 nav computers? i have a new ribon cable and a new laser head but i am not sure that is the problem.
I have repaired several for many board members (e.g. Clemster, TwiggyM5, GBPackersfan68, NathanM5, and others).
1 - 14 of 14 Posts
