1 - 20 of 134 Posts
Hi Guys, I have a few left over from a multipack I bought. These will work with the E39 M5 without any type of modifications.
$10 shipped. PM if interested
What about the clutch interlock??
This is short enough that it won't give you any problems.
If it is short enough to allow my clutch interlock to work, then it will be an inch or two too short to do much good, as the engagement point is considerably higher than the interlock point.
I installed one yesterday... Ordered it just for an excuse to play around with the ///M.
I had to turn the nut all the way down, and I didn't use the washer because with it, I had to be deliberate with pushing the clutch "all the way down" every time I'd start the car to avoid the safety lockout.. I didn't want to be hassled with this for such a minor mod...
That said, the mod isn't minor. It's major. At least in my car. With the removal of about 1 inch of unnecessary pedal travel, the clutch take-up is now very linear and noticeably more progressive. It makes the drive-train feel more compact, if that makes sense.
YMMV, but for me, the feel is great....
Regards, Ed
Regards, Ed
Well said, same experience I had :) great little cheap mod.
Regards, Ed
Same here. You wouldn't think about a one inch difference in travel w/b noticeable, but it is.
Just wanted to bump this up especially seeing as there are a lot of new E39 M5 owners.
This is a small but great mod like the E60 shifter. As mentioned above, it's one of those little things that goes a long way and makes a big difference in feel. Adds about a third of an inch. Direct controls to driveability are noticeably a lot tighter. Highly recommended.
I didn't buy one but I did cut a similar clutchshop which had a longer bolt to the specs provided by JBE46 and it fits perfectly with no added effort in attempting to start the engine. Kinda funny that 01 up owners (including me) had been trying for so long to figure out a bypass to the clutch start when a shorter bolt would have sufficed.
Thanks to JBE46 for the specs.
just installed this and I love the feel of a solid blocker every time I go to shift. Almost like the big boy on my old e36 M3 in feel!
Banned
Have any left?
1 - 20 of 134 Posts
