1 - 9 of 9 Posts
Hey guys I need help everytime I’m shifting and I engage the clutch it makes a clink and I sometimes hear the same noise when I let off the gas hopefully not the trans if somebody experienced the same issues please help!!
check your drivetrain. It can be your differential mount or driveshaft CV joint or some other moving parts.
Thanks I have had a feeling it could be something drivetrain related I will be going under and checking and will inform you guys on what the outcome is thanks for the push to be inspecting the drivetrain!!
Thank you!! everybody thinks this is what could be the source of my problem I will be going under and posting what the problem is to make sure nobody goes through the extra hassle!!!
If it's sort of a not-too-loud fairly high pitched Tink! then my money would be on the driveshaft; although sadly I can't tell you exactly which specific part of the driveshaft.
2002 BMW M5 E39 Dinan
Also check for play in both rear axles cv-joints and the driveshaft cv-joint as well.. it will be very slight but it will be felt through chassis.
Also diff could have slight play in it.. I have poly bushings everywhere and the rear definitely feels clunky even after all the above fixes because sound travels from subframe to car's frame so well with polyurethane.
1 - 9 of 9 Posts
