1 - 20 of 44 Posts
Hey guys,
So I am parting out my Imola Red M5 and looking to get rid of everything asap. The car is also for sale if you are interested. I already have my stock wheel put on but I want to get the suspension sold before I list the car.
I will need stock parts to replace most items so if you have items to trade please let me know.
I am located in Orlando Fl and have no problem shipping just at buyers cost of course :]
KW V2 Coilovers with 7k miles (have receipt of $2k for these) $1300 MOST IMPORTANT I NEED GONE!
VIS Carbon Fiber Vented Hood -$900
BBS CH-R Wheels 19in black and red. Front tires are V12 EVO with good tread rear tires are bald. -$2000
Dinan Carbon Fiber Intakes -$800
Supersprint Cat-Delete Pipes with custom connecting pipes to stock manifold $300
Supersprint x-pipe with welded on resonators with Billy Boat mufflers -$700
Short velocity stacks -$275
AC Schnitzer pedals, ebrake handle, and shifter. Offer up on these guys.
I have tons more photos so just ask if you want to see anything specific!
You can contact me directly at 407-844-6975 text or call if you have any questions.
Thanks,
Blake
is that an ACS rear diffuser? if so, for sale?
In regards to going catless, did you have a tune with the secondary o2's shut off? Could the cat deletes be ran without getting a tune right away?
KW v3 for this cheap?! They should be sold by now.
Discussion Starter · #10 ·
Thanks for the replys and interest!
I do have pictures of the exhaust they are just on my phone so I can email them or text them!
It is an ACS diffuser but it is already sold!
The short velocity stacks help with throttle response and then also add a little more breathing in the higher rpms. Worked well with my tune for it and also heard it works great for supercharged cars.
You can run the cat delete pipes without a tune but you wont be using them to their full potential. My tune actually still uses the rear o2 sensors but turns the engine code off for them. Similar to how it works with the mafs. They are still plugged in and the computer still runs data with them but it is not 100% necessary. You could put a spacer on the o2s and probably not receive a code even without a tune.
Thanks again guys!
Can you share the brand and length of the stacks please? Do you have any dynos to show any gain? I am assuming the motor had the OEM plenum cover? thanks!
Discussion Starter · #14 ·
I am pretty sure the stacks were custom made. I havent removed the off the car to see if there are any markings.
The only dyno sheet I can find is one pre tune where my best pull was around 338.
I can post that if it would be helpful! Like I said though the biggest change you see is in throttle response.
Thanks!
Texted about the cat delete pipes.
How's that Imola Red interior? Fold down rear seats? Condition of the leather? Extended leather?
Hey man correct me if I am wrong but those look like CH's not the CH-R's
1 - 20 of 44 Posts
